August 29, 2026, 08:53:19 am
Hoffman Amps Forum image Author Topic: Dougs 9-pin socket ?  (Read 5393 times)
Offline worth
« on: December 26, 2010, 02:22:26 pm »
I've never used this type of socket.. do I ground the center pin ?
Re: Dougs 9-pin socket ?
« Reply #1 on: December 26, 2010, 02:46:32 pm »
No
The center pin is not a pin
It's not hooked to anything
It can be used as a post if you really need a place for several items to meet.
« Reply #2 on: December 26, 2010, 02:49:13 pm »
Hi tennessee,
That's a good question IMO. I've wonderd about that as some have and some have not. I think it's used as a tie/wiring/turret point, but I wonder if it is sometimes used in other ways, like connecting it to ground to use it as a shield.
          Thanks       Brad       :smiley:
« Reply #3 on: December 26, 2010, 08:58:39 pm »
In TV tuner work, you ground that and jump all bypasses right TO it for minimum lead length.
In audio work, you can ignore it or maybe use it for a tie-point.
Offline stingray_65
« Reply #4 on: December 27, 2010, 12:43:44 am »
Or cut it off with your dikes!
I thought what great idea! I'll tie my grid stopper there!
but my heater wires wanted to pass right there too!
I tend to run my heaters vertical.
SO out with the dikes, off with the lug and add the 3 lug strip under the nut holding the socket down as I always did.
I have a bunch of salvaged Amphenol octals that have a ring of 4 ground lugs, Haven't used one yet. Might be OK on a recto tube, but I've had great luck with following the same ground scheme and heater wiring techniques that I'm afraid to try something different.
just my take
Ray
