September 08, 2026, 01:12:40 pm
Hoffman Amps Forum image Author Topic: Other D'Mars & Plexi Overdrive ideas  (Read 14349 times)
« on: December 31, 2010, 07:07:45 am »
Just a couple of ideas of using a Marshall type amp with a Dumblish type overdrive.
Tubenit
« Last Edit: August 22, 2012, 06:52:57 pm by tubenit »
Re: Plexi Overdrive
« Reply #1 on: December 15, 2011, 09:00:06 am »
Some more ideas here for an OD using a gain stage with cathode follower and tone stack.  Just ideas ...........  amp has not been built
CHECK for errors!
Tubenit
« Last Edit: January 01, 2012, 08:20:14 am by tubenit »
D'Mars Special w/ FX on board
« Reply #2 on: July 27, 2012, 06:02:09 am »
Some more idea that I think might be cool.   I included an FET idea also that could be integrated into this amp design.
« Last Edit: October 02, 2012, 10:11:49 am by tubenit »
D'Mars ODS parallel board
« Reply #3 on: July 29, 2012, 02:41:16 pm »
OK, I have actually built this one. Sounds great.  Nice rich harmonics.  Sweet musical tone.  Clean channcel is superb. When chording, you can hear every note very clearly.
The OD channel can be dialed into getting a harmonically rich tone with some chime and cleaner ................. OR  the Dumblish vowel tone that has some blooming feature to it with the notes swelling and opening up.
An observation that I made is the cathode cap values on the gain stages PRIOR to the cathode follower are VERY important.  Very small changes there seem to have signficant results.  For example on this amp,  a 1.68uf has a sweet spot.  Less than that was thin and more than that had too much grind for me.
CHECK for errors!   Any discrepency ........... go with the schematic.
with respect, Tubenit
« Last Edit: August 22, 2012, 06:54:05 pm by tubenit »
