September 16, 2026, 07:12:50 pm
Hoffman Amps Forum image Author Topic: Power Supply - a new question  (Read 5452 times)
« on: January 01, 2011, 01:38:51 pm »
Today I was reading some old treads here into the forum
here is the thread
http://www.el34world.com/Forum/index.php?topic=9564.msg86813#msg86813
I wrote
what about to put a (little enough small) transformer connected between the CT and ground as to decrease the voltage
I think that I was really wrong on that assumption
if is possible to go up or down in voltage using a second transformer
like they explain here
http://www.geofex.com/Article_Folders/vintvolt/vintvolt.htm
I doubt it will be possible to do the same putting the secondary of a second transformer in series with the CT of the PT, because of the phase change, or I'm wrong now and it is possible ??
I'm confused, can you help ?
Kagliostro
« Last Edit: January 01, 2011, 01:55:41 pm by kagliostro »
Re: Power Supply - a new question
« Reply #1 on: January 01, 2011, 02:13:19 pm »
Other two options
One will be the right one ??
Kagliostro
Offline Tiny_Daddy
  • Get your Amp N Gear!
« Reply #2 on: January 01, 2011, 02:16:18 pm »
Easiest thing to do: run the second transformer to a bridge rectifier. Then connect the output from the bridge to the center tap of the main transformer to add or subtract DC voltage.
« Reply #3 on: January 01, 2011, 05:52:59 pm »
Dead short across small transformer.
Decreases one side, but increases the other side. Result is higher peak DC and more ripple.
Works _IF_ you can get the many windings in correct phase, and the small winding is insulated for the high voltage.
For your specific example:
1) 330V to 300V is a small drop. In many cases you could just live with the higher voltage or drop it with a power resistor.
2) If there is ONLY the one secondary, you could use a small 220V:22V transformer to drop the 220V line to 198V and reduce the secondary voltages.
« Reply #4 on: January 02, 2011, 05:13:59 am »
Many Thanks PRR & Tiny_Daddy
PRR
AC reduction 03
so that way is not possible to have the two transformers in counterfhase
the drop of 30v was only an example
Tiny_Daddy
something like this ?
Kagliostro
