August 29, 2026, 08:54:28 am
Hoffman Amps Forum image Author Topic: Mesa Mark III / Purple Stripe R2 Volume Mod  (Read 5412 times)
« on: January 10, 2011, 07:35:49 pm »
I am having a crappy day with this amplifier. This should have been a 30 minute job
I did the R2 volume mod but i get no tonal response from the 250K pot that is replacing resistor R130
All wires,250K pot and connection points that i have done read out connected on my DVM
Here is what i did:
R 130 is lifted at the north end facing the front panel from the back and a wire is soldered on the empty resistor pad
That wire is soldered to the 250K pot outer terminal
A wire is soldered to the right side of R 131 and soldered to the center 250K pot terminal
Are there traces under this board as i have seen in most all the Mesa amps ?
I did a real clean job and i am at a loss as what to do next. Errrr! :lipsrsealed:
« Last Edit: January 10, 2011, 07:43:01 pm by plexi50 »
