August 29, 2026, 08:52:54 am
Hoffman Amps Forum image Author Topic: Champ idea/question 6v6/6l6  (Read 5046 times)
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« on: January 10, 2011, 11:22:06 pm »
I have an Edcor PT and OT.
The PT-
325-0-325V @70mA
6.3VCT @2A
5V @2A
The OT-
SE 8k/8 ohm
15 watts.
The will be standard 5F1 circuit into a Weber sig 8" with possible UL tap used.
Wonder if I will blow up something running the 6L6?
The PT looks pretty hefty.
Peace.
Re: Champ idea/question 6v6/6l6
« Reply #1 on: January 10, 2011, 11:48:48 pm »
At 8K with that supply, you will want to run the 6L6 at nearly the same current as the 6V6 (around 35mA-45mA). Why would the OT know the difference? About 5.6W out.
If you had a 4K load you could profitably work a 6L6GC much harder, 90mA.... ah, but you only have 65mA available from that 70mA PT. 340V and 65mA suggests 5K load and about 8W output.
That's ass-uming a hollow rectifier. If you go 1N4007 you have 450V available, should run near 60mA, will put 25 Watts in the tube, which is really too-too-much for 6V6, you will need the bigger jug. 10W out.
Offline Madison
    • Funky Dolphins
« Reply #2 on: January 12, 2011, 10:27:31 pm »
Thanks for the info.
I ended up with this OT by accident, unfortunately.
I originally was thinking about a 5Y3.
Hmm, I suppose there is no other way to beef up the output, in this set up, besides increased voltage?
