September 15, 2026, 10:44:11 pm
Hoffman Amps Forum image Author Topic: Sovtek Mig-50  (Read 10097 times)
Offline Leevi
    • Rikstone
Sovtek Mig-50
« on: January 12, 2011, 02:59:46 pm »
I found the following schematics for the Sovtek MIG-50 on the WEB.
Which one is the right MIG-50 schematic?
1. http://www.blueguitar.org/new/schem/sovtek/mig-50.pdf
2. http://www.blueguitar.org/new/schem/sovtek/mig-50h.gif
/Leevi
Offline gldtp99
Re: Sovtek Mig-50
« Reply #1 on: January 12, 2011, 05:46:20 pm »
The Sovtek Mig 50 heads i've serviced most closely matched schematic #1--- not all of them were absolutely, perfectly identical but schematic #1 is the schematic i used...............gldtp99
Re: Sovtek Mig-50
« Reply #2 on: January 12, 2011, 10:31:26 pm »
If i am correct the second schematic is the Mig Midget
The first schematic is the Mig 50
Offline The_Gaz
Re: Sovtek Mig-50
« Reply #3 on: January 13, 2011, 01:50:39 am »
The one on top is the regular Mig, which is more like a Plexi, and the second is the high-gain version (that's what the "H" stands for). The high-gain will have a "HI" and a "LO" input like a 2204 JCM 800. Both schematics should be close, although they were infamous (in my sad small tube-driven world) for using whatever surplus parts they had on hand. In fact, the amps were called "MIGS" because they evidentially used surplus parts from MIG fighter jets1
Offline Leevi
    • Rikstone
Re: Sovtek Mig-50
« Reply #4 on: January 13, 2011, 09:35:23 am »
Thanks for the replies guys. I believe you that it's the schematic #1 but I wonder how
close it is to Marshall Plexi 50. It seems the only bigger difference are the power tubes (5881s).
/Leevi
Re: Sovtek Mig-50
« Reply #5 on: January 13, 2011, 10:28:22 am »
The Mig 50 was a clone of the Marshall circuit. You just dont have the low impedance jacks and it uses a 500 ohm resistor in place of a choke
The power supply resistor node values are also different. Close enough
« Last Edit: January 13, 2011, 10:32:11 am by plexi50 »
