September 15, 2026, 11:07:23 am
Hoffman Amps Forum image Author Topic: Pin 1 on EL34/kt77 Grounded?  (Read 7610 times)
Offline 67polara
  • Here is my Guild 67 polara
« on: January 13, 2011, 11:07:23 pm »
I was just reading someone's post on screen and grid resistors and Just realized I did not ground pin one Of my finals.  What will this cause as far as sound issues?  I did not know about the pin 1 and when I built my TOS I did not ground it.  It works ok I think???
Tony
Offline 67polara
Re: Pin 1 on EL34/kt77 Grounded?
« Reply #1 on: January 13, 2011, 11:10:34 pm »
Wait pin 1 on a KT77 isn't hooked to anything.  Guess I don't have a problem only if I use EL34's right?
Tony
Offline FYL
« Reply #2 on: January 14, 2011, 05:37:30 am »
KT77: 1 is NC (not connected)
EL34: 1 is G3 (suppressor grid). Should be grounded or cathode-connected in most amps.
Your amp should be fine with KT77s, no issues. Making it EL34 friendly is easy...
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: January 14, 2011, 01:31:20 pm »
The real fun begins if you use pin #1 as a tie point for either the screen grid resistor or control grid stopper the way Fender did and then try using an EL-34.  NOT a good plan...
Chip
Quote from: jjasilli
Quote from: PRR
Offline 67polara
« Reply #4 on: January 14, 2011, 06:27:29 pm »
OK, clear this up for me since it is cathode biased to connect to cathode or ground?
Tony
Offline FYL
« Reply #5 on: January 14, 2011, 06:39:45 pm »
Cathode, so G3 will see the same potential.
