September 15, 2026, 05:29:26 pm
Hoffman Amps Forum image Author Topic: Valve universal wiring  (Read 5528 times)
Offline FYL
« on: January 14, 2011, 05:43:31 am »
Just stumbled upon this page with a clever socket wiring scheme allowing to use most 5V valves - 5AR4, 5AS4, 5AT4, 5AU4, 5AW4, 5AX4, 5AZ4, 5CG4, 5R4, 5T4, 5U4, 5V3, 5V4, 5W4, 5X4, 5Y3, 5Y4, 5Z4, 5931, 6087, and 6106. Could be useful.
Offline stingray_65
Re: Valve universal wiring
« Reply #1 on: January 14, 2011, 06:51:45 am »
WOW!
So simple!
I've booked marked it and will likely wire all my 5V rectos like that from now on
Thanks!
Ray
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: January 14, 2011, 06:55:13 am »
Where is the universal B+ lead?
Call me Dan
www.fydamps.com
Offline Geezer
« Reply #3 on: January 14, 2011, 07:01:42 am »
I would think any of pins 2, 7 or 8 could be used.....IOW, any one of the filament connections.
I would probably use pin 8.
G
Offline stingray_65
« Reply #4 on: January 14, 2011, 07:03:27 am »
Just looked thru TDSL at all those recto tubes,
Pin 8 is the universal B+
Ray
seems the only real different recto tube is the 5Y4
The way I've been wiring for years now is pretty universal  :angel
« Last Edit: January 14, 2011, 07:12:23 am by stingray_65 »
