September 15, 2026, 08:55:55 am
Hoffman Amps Forum image Author Topic: Parallel resister math  (Read 6514 times)
Offline Tone Junkie
« on: January 14, 2011, 09:32:18 pm »
Guys Im always crappy with this stuff could you check me and see if Im right, Sorry for such newbie crap. Thanks Bill
100k/39k=28k
100k/68k=40k
Im doing some stuff on switches and need to get it right. :angel
Re: Parallel resister math
« Reply #1 on: January 14, 2011, 09:49:18 pm »
Here's a handy online calculator:  http://www.1728.com/resistrs.htm
Offline Tone Junkie
« Reply #2 on: January 15, 2011, 12:14:25 am »
Thanks worked great and I was right.Bill
Offline JayB
« Reply #3 on: January 15, 2011, 11:01:50 am »
R1*R2/R1+R2= resistance.
You're going to hell faster than Britney Spears running to a Barber shop
« Reply #4 on: January 15, 2011, 03:25:39 pm »
Or you add up the inverse of each resistance value and you get the inverse of the total paralleled value.
i.e.: e.g.: for 220k in parallel with 68k in parallel with 47k = 1/220k + 1/68k + 1/47k = 1/24.67k
JM2CW
Offline Tone Junkie
« Reply #5 on: January 16, 2011, 11:13:06 am »
I actually I have the math problems printed out and pinned to the wall so I can continue to use it for several things involving tube amps its just been 30 yrs since I took algebra and really used it, It was nice to get to the online calculaters and get them to work and check my math.
 Thanks Bill
« Reply #6 on: January 16, 2011, 11:34:39 pm »
There's a machine for that now....
100k/39k=28k ?
100000
1/X
39000
1/X
1/X
In Windows: Start, Run, "calc". The default skin lacks 1/X, use View menu to change to Scientific.
(Yes, if you know why, you can simplify to 100 and 39 and get 28.05..)
« Reply #7 on: January 16, 2011, 11:51:34 pm »
However we must not become dependent on machines.
39K is not far short of 50K. And 50K is exactly 100K||100K. So 50K||100K is the same as 100K||100K||100K. Which of course is 33.3K.
Or -- 39K is a bit high of 33K. And 33.3K is 100K||100K||100K. So 33K||100K is the same as 100K||100K||100K||100K. Which is of course 25K.
The answer is between 33K and 25K. Often this is close-enough.
If you must slice thinner: interpolate. 50-39= 11. 39-33= 6. The 33K cheat is closer to the truth than the 50K cheat. And the answer is roughly 1/3rd of the way from 25K to 33K. 33-25 is 8. 1/3rd of 8 is about 3. 25K+3= 28K. About 28K.
« Last Edit: January 16, 2011, 11:55:12 pm by PRR »
Offline Tone Junkie
« Reply #8 on: January 17, 2011, 01:03:16 am »
PRR man I wish you were my neighbor we would have some fun chats.
thanks Bill
