September 17, 2026, 11:55:36 pm
Hoffman Amps Forum image Author Topic: Rattle in my speakers  (Read 6475 times)
Offline 67polara
  • Here is my Guild 67 polara
« on: January 21, 2011, 09:36:45 pm »
I posted about this a while back and thought it was fixed but it is not.  Certain note on certain strings make a rattle sound.  I have used several different speaks and they all do it.  It is very irritating.  It gets louder as I turn the amp up but is always in the same places.
bass E  Frets                          0,3,6.7.8,11,12,
No rattles on 5 th string
D string Frets                         9,20,21,22
G string Frets                         3,4,15,16,17
B string frets                          11,12
no rattles on high E
Any thoughts?  Oh yea this is a TOS that is somewhat modified and we thought is was due to wrong resistors at the PI.  I changed them and it got a lot better but it is still there.
Tony
« Last Edit: January 21, 2011, 10:03:55 pm by 67polara »
Offline 67polara
Re: Rattle in my speakers
« Reply #1 on: January 21, 2011, 09:46:48 pm »
Oh yea I thought of something else.  When I first get ready to use my amp I heat up the filaments when I take the head out of standby, It is OK for about 30 seconds then the noises start.  This might be an important fact.
Tony
Offline Frankenamp
  • What does this button do?
« Reply #2 on: January 22, 2011, 02:07:23 am »
I had rattles on my new geetar- and thought it was my P*** poor playing, but it turned out that the neck PU was loose. 5 minutes with a small combo screwdriver and my ___ poor playing improved to merely embarrassing. (Hear my father's spectre still grumping about 'no sense of rhythm' or 'no sense at all') :wink:
This problem calls for a bigger hammer!
Offline jeff
  • Need input
« Reply #3 on: January 22, 2011, 08:06:45 am »
Do the rattles get worse as the volume increases?
Is the amp a combo or a head and a speaker cab?
Try it with the amp not on/in the speaker cab.
I built a little combo and had the same thing. I thought it was a rattley tube but I tried 4 different tubes with no luck. When the amp was out of the cab, no problem.
Your noise may be comming from the vibrations and not the circuit.
« Last Edit: January 22, 2011, 09:10:18 am by jeff »
Offline 67polara
« Reply #4 on: January 22, 2011, 09:31:30 am »
It is a Head and it is not sitting on the speaker cab.  It gets louder with the volume so it is an amplified noise.  I have used 3 different speaker cabs and they all do it.  I will check it with another guitar or try my guitar in another amp and see if it is OK.
Tony
Offline 67polara
« Reply #5 on: January 22, 2011, 10:03:10 pm »
Found it!  Feedback resistor problems all better now.
Tony
Offline jeff
  • Need input
« Reply #6 on: January 22, 2011, 11:46:29 pm »
 Could you explain what was wrong. wrong value? wired wrong?
Offline 67polara
« Reply #7 on: January 23, 2011, 12:18:15 am »
The resistor that was supposed to be a 4.7K was coded correctly with yellow violet red but actually measured 47 ohms.  Someone must have had a bad day LOL.
Tony
Offline nateflanigan
« Reply #8 on: January 23, 2011, 08:13:28 am »
Wow you really can't assume anything with this stuff.  Good sleuthing!
