September 18, 2026, 12:54:18 pm
Hoffman Amps Forum image Author Topic: Changing Vibrato 250K Potentiometer from Linear to Audio on AB-763  (Read 5238 times)
Offline WillieBoy
If I change it what will be the difference?  I have notes to change out one of the potentiometers from Linear to Audito, I believe the reverb.
As far as I can tell, changing the pot on the Vibrato should just mean I get less adjustment to about 1/2 way (less fine adjustment).
Thoughts?
Re: Changing Vibrato 250K Potentiometer from Linear to Audio on AB-763
« Reply #1 on: January 24, 2011, 05:04:52 pm »
Which pot are you talking about? AB-763 uses 50K-RA and 3M-RA on vibrato (tremolo). The tone controls are 250K, but they should already be audio taper.
If you are talking about Hoffman's AB-763 with bias modulating tremolo, then you are right.
Offline WillieBoy
« Reply #2 on: January 25, 2011, 10:37:43 am »
Sorry, yes, the Hoffman board.  On that layout, the intensity control is a 250K Linear
« Reply #3 on: January 25, 2011, 01:06:45 pm »
"5" on the dial would be 10%, not 50% intensity.
10% amplitude variation is small to the ear. Less would be nearly nothing.
My feeling is that 1-4 would be too small/subtle to notice, half the dial pretty useless.
If you live on BIG trem, this is dumb. If you thrive on very slight trem, it could be worth a try.
It's a 5-minute experiment. No loss if it does not work out, you can use the pot for something else.
