September 19, 2026, 10:15:28 pm
Hoffman Amps Forum image Author Topic: HMs Lucky7  (Read 9824 times)
HMs Lucky7
« on: January 29, 2011, 01:13:00 am »
just doodling again...  this is a spin of the burger king amp -- with mostly more popular tubes, although i must confess i don't know how common 6AB4s are/were.
criteria:
use 7 pin miniatures - gots a buncha_em & sockets_a_plenty.
use 7 tubes.
at least 7 WRMS output.
like a slot machine payoff: 7-7-7   :grin:
reference below is likely old hat for most of you.
6136/7543 - lo micro./lo hum 6AU6
6AV6 - 1/2 12AX7  sub 6AT6 for slightly less gain.
6AB4 - 1/2 12AT7
6005 -  mil./comm. grade 6AQ5
have everything but the 6AB4s - anyone have any 4 sale?  :wink:
hybrid of a deluxe/matchless w/ a LTPI.
bias should be around 70mA for both tubes w/ ~~15V on the cathodes for ~~10W/tube Pdiss @ idle. at least i think it is... if i tossed the darts proper.
i have not built this but in time i plan to. i have other projects in the works. fishing for sluckey & hoping he bites - the topic of a concept of an all 7pin tube amp came up some time ago...
:wink:
as always, comments & suggestions welcomed.
--ISO
sorted 7pin miniature types.
6AV6 = 1/2 12AX7
6AB4 = 1/2 12AT7
6C4  = 1/2 12AU7
6AT6 = 1/2 6SL7?
6AM4  u  85  gm  9800  rp  8700
6AN4  u  70  gm 10000  rp
6AQ4  u 100  gm  8500  rp 12000  <--- forza massimo !muah!
6AQ6  u  70  gm  1200  rp 58000  <--- 1/2 6SL7?
6BC4  u  48  gm 10000  rp  4800
6BF6  u  16  gm  1900  rp  8500
6BK6  u 100  gm  1600  rp 62500  <--- 1/2 12AX7
6BN4  u  43  gm  6800  rp  6300
6BT6  u  70  gm  1200  rp 58000  <--- 1/2 6SL7?
6BU6  u  16  gm  1900  rp  8500
6C4W  u  17  gm  2200  rp  7700  <--- 1/2 12AU7
6DR4  u 100  gm  1600  rp 62500  <--- 1/2 12AX7
6DZ4  u  14  gm  6700  rp  2000
6ER5  u  80  gm 10500  rp  8500
6ES5  u  75  gm  9000  rp  8000
6FH5  u  50  gm  9000  rp  5600
6FQ5  u  75  gm 12000  rp  6300  <--- semi-remote c/o
6FY5  u  70  gm 13000  rp        <--- remote c/o
6GW5  u  70  gm 15000  rp  5800
6HA5  u  72  gm 14500  rp
6J4   u  55  gm 12000  rp  4500
6N4   u  32  gm  6000  rp  5400
6T4   u  13  gm  7000  rp  1860
Offline jeff
  • Need input
Re: HMs Lucky7
« Reply #1 on: January 29, 2011, 02:34:42 pm »
 If you use 2 50uF caps in parallel instead of one of the 100uF then you'd have 7 filter caps. Now you need to find a 7ohm speaker.
 :grin:
« Last Edit: January 29, 2011, 03:05:59 pm by jeff »
Offline stingray_65
Re: HMs Lucky7
« Reply #2 on: January 29, 2011, 04:15:25 pm »
sent PM
Ray
Re: HMs Lucky7
« Reply #3 on: January 29, 2011, 05:26:56 pm »
 :grin:
or, it is possible to use single 6J6 for LTPI and use 10k Zpri OT. for:
6 tubes
6 filters
6 watts
6669 to replace 6005/6AQ5
6664 to replace 6135/7543/6AU6
that a lot of 6-6-6es...  almost an evil #.
 :angel
665 amps: almost evil amplification.
Offline stingray_65
Re: HMs Lucky7
« Reply #4 on: January 29, 2011, 08:41:43 pm »
If it makes you feel any better, I'll test the 6AB4's on my Eico 666  :angel
Re: HMs Lucky7
« Reply #5 on: January 29, 2011, 10:02:45 pm »
pure evil!! do eeet~!
 :angel
Re: HMs Lucky7
« Reply #6 on: January 29, 2011, 11:54:21 pm »
> a lot of 6-6-6es...
You could build an amp using only 6-pin tubes. 42=6F6 on six legs. 25N6/25B5. 77 can be your voltage amp.
« Last Edit: January 30, 2011, 12:18:23 am by PRR »
Re: HMs Lucky7
« Reply #7 on: January 30, 2011, 01:19:59 am »
ya kno, buttery and i kicked that idea around a some time ago. our antique radio dealer told us that most the numbered tubes of that era were of prized collector value now to keep those older radios going. in other words: he didn't really want to sell us any to build a guitar amp. i can respect that.
we did bounce around the idea of building a guitar amp using military surplus metal clad tubes (6j7, 6SF5, 6SC7, 6l6, etc..) since he had an abundance of them, but it was only as a passing joke and the joke was: let's see if the roadies can tear this one up!
come to think of it, this amp i posted could be built with military_metal_clad valves. hmmm...a high-gain rock-n-roll amp tribute to rosie the riveter.
--ISO
Offline RicharD
    • Toxic Water
Re: HMs Lucky7
« Reply #8 on: January 30, 2011, 09:25:10 am »
I'm ashamed to say I haven't turned on an amplifier or my soldering iron so far this year.  I did clean the lab yesterday.  Bulk trash collection on Monday.  A bit of a motivator.  I need to get back in the swing.  Good to know ISO is picking up my slack.
Offline OldHouseScott
    • Old House Recording Studio
Re: HMs Lucky7
« Reply #9 on: January 30, 2011, 02:17:24 pm »
Haha! Sounds like a Spinal Tap reference!
OldHouseScott
"We put a little quality in everything we build..."
Re: HMs Lucky7
« Reply #10 on: January 31, 2011, 10:06:46 pm »
sent PM
Ray
thanks ray!  you're a good egg.   :grin:
Re: HMs Lucky7
« Reply #11 on: January 31, 2011, 10:07:32 pm »
 :sad:
 :smiley:
