September 20, 2026, 12:11:39 am
Hoffman Amps Forum image Author Topic: Doug's grounding scheme  (Read 6529 times)
Offline steven
« on: January 30, 2011, 02:27:08 pm »
Well, after building about a dozen amps, I built one where I finally _really_ followed Doug's grounding scheme, to the letter.
Whuddya know, quietest amp I've built. The only hum is coming in through the single coil pickups.
"do not try and re-invent the wheel" indeed.
Thanks, Doug. I'll keep this wheel.
steve
Offline samato
Re: Doug's grounding scheme
« Reply #1 on: January 30, 2011, 02:40:15 pm »
I tried my best to follow Doug's grounding scheme to the letter but I have so much noise the amp is unusable.  I don't blame the scheme though, I'm sure I've done something wrong.
« Reply #2 on: January 30, 2011, 03:19:26 pm »
I've used Doug's grounding scheme on every amp I've built. It works great for me!
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: January 30, 2011, 04:51:08 pm »
Unable to leave well enough alone, I've never exactly followed Hoffman's grounding scheme.  It always is my starting point though.  Insulated input jacks with a separate ground lug very close by give me more confidence.  Likewise, insulating the speaker jack so I can experiment with its grounding point has worked out well.  High current there.  Also, advice to ground the PT actually at the negative end of the "reservoir cap" (first in power rail) makes sense in terms of minimizing ground loops.
All that said, Hoffman's approach has worked really well for me.  If you study Doug's layouts & grounding scheme closely, it's very close to the "galactic" ground approach Kevin O'Connor advocates.
Indeed a big THANK YOU goes out to Mr. Hoffman.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline samato
« Reply #4 on: February 02, 2011, 04:54:03 pm »
My amp is very quiet now and my problem had nothing to do with Doug's scheme.  The fact that the amp is quiet now probably has a lot to do with Doug's grounding scheme though, especially considering the challenges with my build - transformers very close to each other, very small chassis, etc.
