September 08, 2026, 07:50:31 am
Hoffman Amps Forum image Author Topic: 5E3 6L6 conversion suggested OT??  (Read 87863 times)
« on: June 15, 2005, 07:54:37 am »
    > Archives
        > 5E3 6L6 conversion suggested OT??
<< Prev Topic | Next Topic >>
Author  Comment
bnwitt
Senior tube assistant
(11/19/03 9:08 pm)
24.130.216.195
Reply | Edit | Del All  5E3 6L6 conversion suggested OT??
 I am building a 5E3 deluxe for a player who wants more power than the standard setup so I am making changes to the circuit and putting 6L6's in instead of 6V6s and shooting for around 25-30 watts. I already have a P12Q speaker and have made changes to the appropriate resistors but I need a 30 or 35 watt OT with an 8 ohm secondary (or multiple secondary would be fine). Anyone have a suggestion for a trannie that will fit well on the Weber chassis. Doug, if you have one, I need to place an order with you for some other stuff anyway.
Barry
eddiejg
(11/20/03 10:33 am)
24.186.54.30
Reply | Edit | Del  5E3 6L6 conversion suggested OT??
 Barry-
I built a 5E3 with 6L6's.
I used a Fender # 047269.
According to the Angela site, it is rated for 20-35 watts.
It has a 4 & 8 ohm tap.
It's 3" X 2.75" X 2.5" tall, mounting centers between the two mounting holes is 3.625".
I don't know if it will fit on the Weber chassis.
I do know the amp sounded really good, with the same speaker you're using & a Hammond 270FX transformer.
For more wattage, you would probably want to use a higher primary voltage than that (275-0-275).
Doug's Bassmaster output transformer might be another choice.
-Ed
bnwitt
(11/20/03 1:22 pm)
12.129.246.93
Reply | Edit | Del  Re: 5E3 6L6 conversion suggested OT??
 Ed,
thanks for the reply. It looks like Angela no longer stocks the OT but Bruce at mission amps says he has some. His suggestion is to use the 8ohm tap for 6L6's and the 4ohm tap for 6V6's. I will probably put in a toggle to make it a dual use amp.
Barry
eddiejg
(11/20/03 2:25 pm)
24.186.54.30
 Barry-
Yeah, I think that's the same one.
I used the 8 ohm for both 6L6 & 6V6, but his way sounds better.
Angela does still carry them, but you have to look under guitar amp parts, then Fender transformers.
Of course, that doesn't mean they have them in stock.
bnwitt
(11/20/03 4:32 pm)
12.129.246.93
 Ed,
I checked the angela site and they have them on sale for $29. Thanks for the tip.
Barry
 Email This To a Friend
 Topic Commands
jump to:  Tube Amp Building - Tweaks - RepairsNew Product SuggestionsPraises - Complaints - SuggestionsBuy - Sell- TradeArchivesWelcome - Read me first
- Hoffman Amplifiers - Archives - Hoffman Amplifiers -
Powered By ezboard® Ver. 7.32
« Last Edit: June 15, 2005, 07:59:35 am by EL34 »
