September 17, 2026, 01:48:04 pm
Hoffman Amps Forum image Author Topic: Screen resistor values?  (Read 6654 times)
Offline firemedic
« on: February 12, 2011, 03:30:32 pm »
Hi all,
I'm getting ready to build a Pro Reverb AA165, my last build probably for a while. I'm getting used to putting Pentode/Triode switches in my builds & I use the Torres layout from "Inside Tube Amps". According to Dan Torres, the screen resistors must be changed from 470R to 1K. He deems it to be a Very Important Step that must be done.
Is this true, & if so why? I'd like to keep the values as close to the original schem as possible but I like my 1/2 power switch too much to give it up.
Offline FYL
Re: Screen resistor values?
« Reply #1 on: February 12, 2011, 07:26:07 pm »
Torres recommendations are always to be taken with a grain of salt. 470R is a minimum with 6L6s, you may use 1K or 1K5 with no ill-effects and get slightly better screen protection - could be useful at stage levels with the amp fully cranked. Use at least 3W-rated FP resistors.
« Reply #2 on: February 12, 2011, 08:42:38 pm »
See:  http://archive.ampage.org/threads/0/ampdiy/003858/DR_screen_resistor-3.html
In triode mode the screen is connected to the plate.  But the plate draws much more current than the screen can handle.  The larger resistor limits current and protects the screen.
Offline firemedic
« Reply #3 on: February 12, 2011, 08:48:20 pm »
Thanks guys, that clears it up.
Offline GuitarPilot65
  • Music by Lee/Lifeson; Lyrics by Peart
« Reply #4 on: March 11, 2011, 05:48:25 pm »
I swapped the stock 470Ω screen grid resistors for 1kΩ/ 3w flame-proof ones in my DRRI (R62 & R63).  Sounds great.
« Last Edit: March 12, 2011, 08:40:43 am by Blondie »
1993 Brown Fender '63 Vibroverb RI (6G16)
1994 Blonde Fender '65 Deluxe Reverb RI (AB763, modified [by me])
Offline firemedic
« Reply #5 on: March 11, 2011, 06:53:40 pm »
I did the same thing, 1k 5w. It sounds real good.
