August 29, 2026, 08:48:26 am
Hoffman Amps Forum image Author Topic: spst switch did i order the wrong switch?  (Read 4385 times)
Offline mikhett
« on: February 19, 2011, 12:21:31 am »
I need a new power switch(on/off) for a 1967 Ampeg reverbrocket.It has 4 terminals the one term goes to the fuseholder and the other term goes to the one side of the pt primary winding.the 2 bottom terms go  to ground .one at the pl connection the other term to a filter cap ground.thats the way it was originally.this original switch should be a spst switch,right?Doug sent a 3 term switch i think is spdt.HELP.Thanks Mike
Offline jeff
  • Need input
Re: spst switch did i order the wrong switch?
« Reply #1 on: February 19, 2011, 05:33:07 am »
If it has 4 terminals I don't think it could be a spst. spst stands for single pole single throw. The pole is how many things you're switching and throw is how many things you switch it to. A spst would have only two terminals. I think you need a dpst. Sounds like you're switching two things at once. Fuse to transformer and something to ground.
do you have a picture?
« Last Edit: February 19, 2011, 05:53:11 am by jeff »
