August 29, 2026, 10:32:59 am
Hoffman Amps Forum image Author Topic: suitable pwr trafo for the new project  (Read 6698 times)
Offline mat
« on: February 19, 2011, 03:49:04 pm »
Would these specs ( Primary 230V, secondary 230V 0,12A, 20V 0,12A and 6.3V 4A.) be enough for amp project that contains 12ax7 and ef86 for the pre, 12ax7 for PI and two el84's for the power tubes ?
Thanks,
Mat
mat
Offline FYL
Re: suitable pwr trafo for the new project
« Reply #1 on: February 19, 2011, 07:19:29 pm »
Just calculate total power consumption using typical values from the datasheets. Heater current is fixed, plate current depends on the actual amp and output level - take the max from the datasheets.
2 x 12AX7 = 300 mA H, 3 mA Pl (two sections) max. => 600 mA H, 6 mA Pl
1 x EF86 = 200 mA H, 6 mA Pl max.
2 x EL84 = 800 mA H, 50 mA typ. => 1.6 A H, 100 mA Pl + Sc
Total = 2,4 A H, 112 mA Pl + Sc
Your PT is OK with it's 4 A 6.3 V and 120 mA B+ ratings. Heater voltages could be on the high side because the 6.3 V winding will be loaded at 60 % only - a couple of dropping resistors could be needed if you fancy tube longevity.
Offline mat
« Reply #2 on: February 19, 2011, 11:13:04 pm »
Thanks FYL for the math. I'll further study the numbers.
mat
Offline stingray_65
« Reply #3 on: February 19, 2011, 11:14:45 pm »
you can knock down heater voltages a little at a time by adding a diode or two
(------>|------4,5-----
(------|<-------9-----
That is if it is a problem.
Ray
Offline mat
« Reply #4 on: February 20, 2011, 03:55:24 pm »
Ray
Sorry Ray, how do I connect the diodes to the heater wires if I want to drop the voltage ?
So there would be enough juice for one more 12ax7 on the amp with this trafo ? maybe a buffered loop..
mat
Offline FYL
« Reply #5 on: February 20, 2011, 04:37:57 pm »
Just add 3 mA for plate and 300 mA for heaters...
Offline J Rindt
« Reply #6 on: February 20, 2011, 06:53:39 pm »
Keeping in mind I am new to electronics....
So, you do not need 2 diodes, cathodes reversed, in parallel, for each heater wire to allow for the AC change in polarity.?
Ray
« Last Edit: February 21, 2011, 12:32:27 am by J Rindt »
Offline J Rindt
« Reply #7 on: February 21, 2011, 11:46:02 pm »
Can somebody set me straight on this.?
Thank You
Online sluckey
« Reply #8 on: February 22, 2011, 06:49:55 am »
Your thinking is correct. Ray's circuit looks like a half wave rectifier to me and that will knock the voltage down too much.
