September 18, 2026, 11:59:21 am
Hoffman Amps Forum image Author Topic: hum gets louder when PI tube is removed  (Read 4170 times)
Offline musicfixerupper
« on: March 02, 2011, 04:16:33 pm »
Hi, i am working on a super reverb clone and am having problem with a hum that gets louder when the PI tube is removed. Seems weird that it get loud when the tube is removed.
Offline LooseChange
    • Fix Your Darn Amps
Re: hum gets louder when PI tube is removed
« Reply #1 on: March 02, 2011, 04:34:26 pm »
At least it does not hum when its off!  :smiley:
Not sure what is ther problem but I can understand the hum being louder with the tube pulled.
Something is obviously wrong with the PI wiring or the voltage supply.
Call me Dan
www.fydamps.com
Offline octal
« Reply #2 on: March 02, 2011, 06:12:51 pm »
I would start by checking the bias supply for ripple and correct DC voltages on both control grids of the output tubes. (I think LC was getting at this.) When the PI tube is plugged in, its plate resistance can serve like a voltage divider to reduce hum that is back-fed in from the bias feed resistors going to the output tubes.
Has this build ever worked properly?
« Reply #3 on: March 02, 2011, 06:31:45 pm »
Here's an idea to consider...
The hum may be caused by a big imbalance in current flowing in the OT primary. May be poorly matched tubes, bad tube, or a faulty OT, or biasing that causes one tube to conduct more than the other. When you pull the PI tube, you break the NFB loop causing the gain of the output stage to increase, which makes the hum louder.
