September 17, 2026, 01:11:38 pm
Hoffman Amps Forum image Author Topic: 1973 Fender Silverface Vibro Champ low volume problem  (Read 7954 times)
Offline silverface
« on: March 05, 2011, 06:08:45 pm »
Hi everyone i'm a newbie here and was wondering if anyone ever had a problem with a fender silverface vibro champ with a low volume problem. What mine is doing is there's no volume from 1 to 3 on knob and starts to get loud at 4 and up but not as loud  as another champ i have. I already swaped the volume pot with a new one and tried swaping  tubes from another champ with no change. Has anyone ran into this before? Thanks!
Offline rafe
  • I have tube amps
Re: 1973 Fender Silverface Vibro Champ low volume problem
« Reply #1 on: March 05, 2011, 09:12:05 pm »
the speaker needs to be a 4 ohm has someone changed it?
Rafe
Offline silverface
« Reply #2 on: March 05, 2011, 10:59:30 pm »
The speaker is a weber 8sigA-s4 and that should be ok its a 4 ohm
Offline rafe
  • I have tube amps
« Reply #3 on: March 06, 2011, 12:25:31 am »
I just noticed that this is posted in "Introduce yourself" You need to re-post it to "Tube amp building-tweeks-repairs" you will get feedback that way. edit: moved to correct forum by a moderator
Do you know how to take voltage readings? Safely?
Anyway it could be a number of things, There were a few threads on champs you could try to find, plus there is a great library here. I had a resistor that was never attached in my 74 VC but it still functioned albeit poorly.
« Last Edit: March 06, 2011, 07:33:18 am by Geezer »
Rafe
« Reply #4 on: March 06, 2011, 11:53:48 am »
What's that? The removal of nfb? It wouldn't have an affect on poor performance though unless it was wired differently from original. Now if it was a grid leak, this could be a different story.
The vol issue seems like the vol pot's divider network has gone awry somewhere?
Offline rafe
  • I have tube amps
« Reply #5 on: March 06, 2011, 12:27:11 pm »
I'm just saying that the problem with mine was the 220K grid resistor not being attached properly
(No solder).
Post some voltages?
Rafe
« Reply #6 on: March 06, 2011, 03:18:43 pm »
Post some voltages? Ditto, actually post all voltages.
Also try the tube amp debug section at www.geofex.com
Offline silverface
« Reply #7 on: March 06, 2011, 05:59:19 pm »
 Yea i'll have to do some research and check voltages and get back. Thanks!
