September 17, 2026, 07:15:31 am
Hoffman Amps Forum image Author Topic: 18 Watt Lite iib phasing issue help?  (Read 5722 times)
Offline ncusack
« on: March 07, 2011, 06:49:42 am »
Hello,
I have built an 18 watt lite iib with master volume and the amp sounds wonderful except when things get dimed. When everything is up to its max the tone still sounds good but there is a slight sort of phasor effect that happens. I'm just wondering if other people have had issues like this elsewhere and what some of the possible causes might be?
Cheers,
Neill
Offline OldHouseScott
    • Old House Recording Studio
Re: 18 Watt Lite iib phasing issue help?
« Reply #1 on: March 07, 2011, 08:25:40 am »
That's not uncommon with EL84 amps, and from various posts I've read here and other places, seems to stem from grid conduction on the EL84s causing the coupling caps to charge and shift the bias, resulting in crossover distortion in the output.
Here's a link to the Paul Ruby mod that describes using zener diodes to reduce the cap charging effects:
18-watter buzz info
Here's a discussion on another forum about both the Paul Ruby mod and another mod, using a zener across the cathode resistor of the power tubes to limit bias shift there as well:
Zener diode mods
You can also do a search on "EL84 swirl" and probably find some related discussion.
OldHouseScott
"We put a little quality in everything we build..."
