September 08, 2026, 12:17:08 pm
Hoffman Amps Forum image Author Topic: LDR use instead of relays and/or pot in Tube amps - need infos  (Read 15229 times)
I'm interested to discover LDR possibilities of use in a tube guitar amp
In this page I've read the author used an Home Made optic substitute for relays
http://home.arcor.de/guido.boehne/Boogie%20new.htm
the page is in german but you can translate with google translator
The channel switching is no longer as in the first version with relay, but with optical switches. These switches consist of a LDR (Light Dependent Resistor) of type A1060 and a super bright yellow LED, which are wrapped in black shrink tubing. The LDR has a resistance in total darkness of> 20MOhm. If it is illuminated by a light source with a wavelength of about 600nm, decreases its resistance decreases to about 400 ohms. This process happens smoothly without jumps in a few split seconds, thus preventing an unwanted Umschaltknacken.
I've find this LDR
http://it.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0596141
can it be used that way ?
Also in Merlin's book there is a description to use an LDR and a led in some position of the amp, instead of conventional potentiometers, because with an LDR you don't get scratch noise
Do you know other available use of LDR in guitar tube amps ?
which models are easy to be find to build Homemade Units (LDR + Led)
there are commercial products for this purpose (optic unit builds) ?
Kagliostro
« Last Edit: March 13, 2011, 12:13:48 pm by kagliostro »
Re: LDR use instead of relays and/or pot in Tube amps - need infos
« Reply #1 on: March 13, 2011, 12:19:27 pm »
You may get a euphoric feeling from rolling your own but there are lot's of readily available opto devices. The vactec VTL5C1 opto switch is used in a lot in guitar amps...
EDIT... Here's one I rolled a few years ago using RadioShack parts.
« Last Edit: March 13, 2011, 12:39:35 pm by sluckey »
« Reply #2 on: March 13, 2011, 12:53:36 pm »
The SLO100 uses optocouplers (instead of relays) for channel switching. (Is that what you were asking?)
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: March 13, 2011, 06:28:01 pm »
If you want to learn more, there were several long discussions on the subject of LDRs for switching purposes on the AX84 forum a few months ago.
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #4 on: March 14, 2011, 03:48:28 pm »
Many Many Thanks Sluckey - Tubeswell - Fresh_Start
for the given info
Kagliostro
Offline jerrydyer
  • Make it one of a kind
« Reply #5 on: March 15, 2011, 11:06:26 am »
I love em. I use them in mine I also had a guy build me a board like the one on the Mojotone site.  I can put togther a cheap kit if you want to play around with them. the vactrols arent cheap though. It takes to to make one SPST switch.
