September 15, 2026, 01:14:06 am
Hoffman Amps Forum image Author Topic: X88R preamp - a very nice turret job - I'm looking for layout  (Read 6917 times)
I've seen this well build turret preamp (Slo X88R)
unfortunately were I find the photo the author of the job was unknown
http://img398.imageshack.us/i/x88remptyboard7ds.jpg/
http://img398.imageshack.us/i/x88rpopulatedboard2ok.jpg/
http://img398.imageshack.us/i/x88rallboardspopulated5fw.jpg/
http://img398.imageshack.us/i/x88rallboardspopulatedside5lr.jpg/
http://img398.imageshack.us/i/x88rfullyassembled8ry.jpg/
http://img398.imageshack.us/i/beforeputtingthecoveron9cp.jpg/
as I like very much that build (you not ?) I would have the relative layout
does someone knows more of that turret X88R build ?
someone has a link to the layout ?
Many thanks
Kagliostro
« Last Edit: March 20, 2011, 05:14:33 pm by kagliostro »
Offline TubeGeek
    • Glacier Amps
Re: X88R preamp - a very nice turret job - I'm looking for layout
« Reply #1 on: March 20, 2011, 06:06:32 pm »
Wow, excellent workmanship there! :huh:
Offline nateflanigan
« Reply #2 on: March 21, 2011, 06:30:22 am »
That is quite impressive.  Made me want to try out my detective skills...
I found this post at AX84...
'* More Pics Up *'
Author:   Dmitriy (guest: search)
Date:    Tue, Aug 20th, 2002 @ 13:52 (9 years ago)
Looks VERY good.
A few bits of advice:
- Solder your wires to the top of turrets and form a nice dome of solder when doing so. It looks much nicer than wrapping them around turrets, especially for stranded wire.
- Next time you use radial electrolytic caps, consider installing the turrets from the "back" of the board and "dremeling" them into nice eyelets. That's what I did in my X88R - all caps in the power supply are radial. This way you'll be able to install the radial caps the way they were supposed to be installed.
How many X88R builds with radial caps can there be?  Seems like a clue.
Also found this mysterious place...
http://www.slocloneforums.com/index.php
Let us know what you come up with.
« Reply #3 on: March 21, 2011, 02:50:03 pm »
Hi Nateflanigan
an also
did you see ? ........... wires are soldered to the top of turrets
there is more of a clue
Unfortunately I've problems with my registration to the AX84 forum
Kagliostro
« Last Edit: March 21, 2011, 02:54:38 pm by kagliostro »
Offline Tone Junkie
« Reply #4 on: March 21, 2011, 04:21:40 pm »
kagliostro Ive seen you at sloclone forums and there is alot of info over there about the x88r.
Thanks Bill
« Reply #5 on: March 21, 2011, 05:51:07 pm »
Hi Tone Junkie
Yes but I wasn't able to find a turret layout
Kagliostro
