July 30, 2026, 08:49:32 am
Hoffman Amps Forum image Author Topic: Bassman Ten rebuild  (Read 4431 times)
Offline blues man
  • I hate solid state amps
Bassman Ten rebuild
« on: April 03, 2011, 08:10:56 pm »
I just finished the build. Its a plexi for the lead channel and a 6g6 bassman for the rythm. I have posted the sch. I have one issue so far. When you dime the vol on the lead channel you can only get the master up to about 3/4. Above that it sounds like it's becoming unstable. Feed back as well as some possible parasitic oscillation. Any tips on taming it down a little. I thought about maybe changing out the 1.5k res on the power tube grids to a higher value like 5.6. would that help?
Offline VMS
Re: Bassman Ten rebuild
« Reply #1 on: April 04, 2011, 09:23:18 am »
What happens if you remove V3 tube?
Also, how close are the volume pot wires to the wires of tonestack and master pot?
Offline blues man
« Reply #2 on: April 04, 2011, 07:06:41 pm »
Thanks for the tip VMS. The master vol wire was routed right by the vol wire and pot. I rerouted the wire and cut off about 4" of wire. I did use shielded wire originally but layout does matter. It definitely got rid of the parasitic. I didn't have time to thoroughly check it out but will tomorrow. I'm trying to rush the build to much and get it done. I just signed up to take the masters electrical exam. The amp building is going on the back burner for the next month.
