September 08, 2026, 10:34:20 am
Hoffman Amps Forum image Author Topic: DN2540 MOSFET in a cathodyne  (Read 13051 times)
Offline bigugly
« on: April 10, 2011, 01:40:00 pm »
I've been thinking about using the DN2540 MOSFET in my next amp as a split load phase inverter. I think I can just sub it in where a 12AX7 would normally go but I have very little experience working with discrete SS devices. Any advice would be appreciated.
thanks,
James
Life, Liberty, and the Pursuit of All Who Threaten It.
Offline FYL
Re: DN2540 MOSFET in a cathodyne
« Reply #1 on: April 10, 2011, 02:29:01 pm »
I've never used a depletion MF in a cathodyne but it should work OK.
« Reply #2 on: April 10, 2011, 04:50:38 pm »
i didn't know they still made them! i thought that enhanced is just about all that's being mfg.   that's what i get for making assumptions.   :BangHead:
--DL
Offline FYL
« Reply #3 on: April 11, 2011, 04:06:41 am »
Depletion MFs are quite rare and expensive but they are still being manufactured.
« Reply #4 on: April 11, 2011, 07:23:13 am »
Interesting matter
I'm interested to know your further experiment in this solution
from my part the interest comes because of the use of one less tube (one less filament consumption) in converting old amps to guitar use
the solution with the two cathode bypass caps on the power tubes comes from the Geezer idea as to obtain a variable output power ?
(http://www.el34world.com/Forum/index.php?action=dlattach;topic=4401.0;attach=3956)
Kagliostro
Offline bigugly
« Reply #5 on: April 11, 2011, 08:52:10 pm »
Interesting matter
Kagliostro
I've got a finished layout done and I'll start putting it together while I wait on the DN2540s to come in. My desire was to take my favorite amp and give it a push pull power amp without having to add another 12AX7.  The decreased filament consumption, extra socket, and corresponding hole in the already cramped chassis i have were all added benefits. I have also wanted to try Geezer's idea since I saw it. Its seems a viable alternative to a more complex VVR circuit.
Offline bigugly
« Reply #6 on: April 15, 2011, 07:58:46 am »
okay! I got all the parts in today so it looks like I'll get to build the first prototype this weekend. the only change I'm going to make to the schematic in my first post is to get rid of the dual ganged post PI MV.
the only manufacturer that I know of for depletion mode MOSFETS is Supertex but at $1.60 each I wouldn't call them expensive.
Offline 38Super
« Reply #7 on: April 17, 2011, 07:07:31 pm »
This is an interesting project.  True, a depletion MOSFET has threshold characteristics closer to a vacuum tube (device is on with Vgs=0V), but is not required in this application.
If you look at the common source connected Q1, the voltage on the source = [V1A (DC plate voltage) - Q1 V(on)]  This voltage sets Q1's operating point current.  This same current flows in the drain resistor, since Igate(DC)=0.
A depletion mode MOSFET (same w/ JFET) has a negative threshold voltage, whereas a typical garden variety MOSFET (enhancement mode) device has a positive threshold voltage of several volts (need to apply Vgate-source to turn device on).  From the circuit's perspective, the difference in using an enhancement or depletion FET is a few volts difference in the V(on) voltage, that is the voltage gate to source when the device is conducting a few mA.  This will affect bias current in Q1, which can be dialed in by adjusting V1A cathode current or adjusting R14/R15
cheers,
rob
