September 08, 2026, 12:21:05 pm
Hoffman Amps Forum image Author Topic: 5-way switch & dpdt switching  (Read 5714 times)
« on: April 12, 2011, 06:22:57 am »
Guys,
Nothing really that special here other than to share what I've done on one of my Tele's that has DiMarzio FastTrack1's and  a Chopper pickup.
The S-S-S label is somewhat misleading because they are humbuckers emulating a strat pickup. I simply chose to use that label to distinguish from the dual coil side by side buckers.
I wanted a VERY clean tone out of the guitar as an option for when I needed a super clean almost Tele or acoustic type clean on a song.
So what I did was wire the neck pickup out of phase with the middle pickup. That way the neck/mid setting has a remarkably clean tone when I need that for finger picking or an acoustic/Tele type clean. I virtually never used the neck/mid setting prior to this.
However, the bridge/middle setting still has somewhat of that strat "quack" sound that I like alot.
For those of you who might want an editable schematic that you can change to record your own pickup and switching wiring, there are editable versions here:
http://www.el34world.com/Forum/index.php?topic=11438.new#new
EDIT:  I added a Cruiser neck pickup to one of my Tele's.  And rewired one of the DPDT switches to combine the neck and bridge together.
« Last Edit: December 01, 2011, 06:34:59 am by tubenit »
