August 29, 2026, 10:29:59 am
Hoffman Amps Forum image Author Topic: 5E3 deluxe circuit in chassis with an extra knob  (Read 6320 times)
Offline terminalgs
« on: May 04, 2011, 03:05:47 pm »
my Hoffman 5E3 circuit is in a chassis with an extra knob hole on the control panel.  Any ideas of what I can do with it?   I don't want to embellish the tone/volume circuit with anything that would suck down the level  (like adding a treb/bass t/s or something)..,  I have some rotary switches I could use ( a 3P2T make-before-break rotary, some 2P6T rotaries,etc) and all kinds of knobs.
I thought of using a 3P2T to switch between the .1 1st coupling caps to .001,  and I thought about a one knob tremolo (ampeg style with a LDR in series with the signal.,  I can add a 12AX7 to get another triode stage....  but a trem with a only a speed knob? (i guess if the LDR was on channel no.2 before the volume knob, and if chan1&2 where chained together, that volume knob would be sort of an intensity knob...
anyhow, before I dream something up,  I thought I'd ask people with more experience.
Offline firemedic
Re: 5E3 deluxe circuit in chassis with an extra knob
« Reply #1 on: May 04, 2011, 04:30:40 pm »
Maybe a one-tube reverb w/ no dwell control?
Offline terminalgs
« Reply #2 on: May 04, 2011, 09:52:25 pm »
that's a good idea,  I don't think my cab has room for a full size tank, tho.
Offline firemedic
« Reply #3 on: May 04, 2011, 10:06:38 pm »
I got a short tank, I think from tubedepot.com, but check doug's store first. It works great.
« Reply #4 on: May 05, 2011, 04:09:51 pm »
You can do lots of things like making treb & bass instead of only a tone control is a good one and make it switched to either bypass or ground lift the tone stack. Sounds really good on a 5E3-ish build. But, you can put in a presence pot w/ pp switching to swith out NFB all together, down all the way it's a simple NFB and turned up it's your presence control. You could also make a PPIMV or even possibly a VVR master power output control.
Offline stingray_65
« Reply #5 on: May 05, 2011, 11:20:45 pm »
VVR
Offline terminalgs
« Reply #6 on: May 16, 2011, 03:47:15 pm »
this is what I ended up doing.  the 3 switches are ganged together in a 3PDT rotary switch.
