September 17, 2026, 02:35:43 am
Hoffman Amps Forum image Author Topic: 1982 Marshall Anniversary Series 4210 / Input Noise Problem  (Read 5466 times)
1982 Marshall AS 4210 amplifier. I have a small amount of voltage at the input jack. When i turn my volume pot on the guitar it wisps back and forth. It does this using 5 different guitars so a guitar isnt the problem. If i run a screwdriver on the chassis you get that voltage crackle.  This is suppose to be the same as the 2205 but i see differences so i am not going by the 2205 schematic.  All i can think of is i have a bad coupling cap on V1 but i dont see one on the 4210 schematic until you get to V2A. This amp is weird. It is loud but not as loud as i think it should be with two 6550 power tubes. The Clean channel breaks up early and has no clean headroom . There is no clean to it period.  :help:
The clean channels EQ is wired way differently than what i am used to seeing in most all amp
All tubes are brand new as of yesterday
« Last Edit: May 15, 2011, 07:33:10 am by plexi50 »
Re: 1982 Marshall Anniversary Series 4210 / Input Noise Problem
« Reply #1 on: May 15, 2011, 07:27:58 pm »
Found my problem. Some one has did some hacking and removed the .047 cap that was a part of the input grid on this amp
Also they changed many cathode resistors out for 820's on V1 & V2 that made the amp overly gainy and dark
Changed the 220K plate resistors out for 100K values. Changed tonestack values for clean channel to 250pf / .1 Bass and .047 Mid
Slope was 33K but is now 100K for the clean channel
Slope for Dirty channel on schematic says 68K but is a stock 33K. Treble cap is 220pf and have changed Bass cap to .1 & Mid to .047
Will fire up tommorrow
« Last Edit: May 15, 2011, 07:30:12 pm by plexi50 »
Offline LooseChange
    • Fix Your Darn Amps
« Reply #2 on: May 16, 2011, 04:35:02 am »
Not that I though the cap was missing, but that would have been my first place to look.
Call me Dan
www.fydamps.com
« Reply #3 on: May 16, 2011, 08:40:00 am »
A first for me. This amp is using 9 Tropical fish caps. The solder on them looks to be original. How can that be? I thought those caps were a 60's-70's thing. Just seems to me like some one made a lot of changes. Though i have not seen this amp before
It is finished. It sounds great. It almost seems to me that this is the worst Marshall i have ever seen as far as the clean channels EQ goes. More along the lines of a Peavey Triumph in the way it is layed out and put together
At least i now know what to do when the next one comes along
« Last Edit: May 16, 2011, 07:56:00 pm by plexi50 »
