August 29, 2026, 10:30:43 am
Hoffman Amps Forum image Author Topic: Paralleling inputs on a 5F6-A  (Read 6159 times)
Offline Bub
« on: May 16, 2011, 09:59:51 am »
Hi Gent's
I would like to use a toggle switch to bridge both triodes. Standard 4 input jacks set up. I ran a jumper as in TUT 1, page 5-32, figure 5-43, just bridging both triodes with a switch, nothing but squeal. Can I run the Bright channel through the toggle so when it is on both grids are running off the Normal input jacks and I disconnect the Bright jacks? I guess I'm also wondering why the squeal.
Thanks for any help
Rob
Offline Bub
Re: Paralleling inputs on a 5F6-A
« Reply #1 on: May 16, 2011, 11:22:58 am »
It works perfect.
Rob
Offline rzenc
  • TUBES RULE
« Reply #2 on: May 17, 2011, 09:31:55 am »
I did it to my own 5E3 and it works.
With a simple SPST switch, you can solder the junction of 68K input resistors on switch tabs and run shielded cable to pins 2&7 on first preamp tube. When you engage switch, both grids will receive the same signal...
Hope this helps.
Best Regards,
Rzenc
« Reply #3 on: May 17, 2011, 03:58:03 pm »
I have done a similar thing to a 5F6A circuit in one of my own amps. Except I don't have a switch, I just ditched two of the input jacks (went to one hi-lo set that goes to both grids together) and use the vol controls to mix the two.
« Reply #4 on: May 18, 2011, 06:48:41 am »
That's true. But if you look at your circuit you'll see that only half the guiter signal gets to the grids when the switch is closed. Essentially the same as playing thru the LOW input jack. You'll need a SPDT switch to isolate one set of inputs when you parallel the grids in order to get the full guitar signal to the grids. Take a look...
Offline rzenc
  • TUBES RULE
« Reply #5 on: May 19, 2011, 11:07:59 am »
I will give it a try and report back.
Thanks!!!
Best Regards
Rzemc
