September 17, 2026, 05:11:43 pm
Hoffman Amps Forum image Author Topic: Mosfet CF and mini-TOS  (Read 12883 times)
« on: May 20, 2011, 05:49:53 am »
Guys,
The other day I was using my TOS with the FX-Reverb unit that I built that goes with it, and it sounded great.
And then for the fun of it, I tried the TOS withOUT the FX-Reverb unit and discovered that the cathode follower behind the 5879 still gave it a really super nice transparent tone when the OD was engaged.  Without the OD engaged,  the clean channel does NOT sound as good (running the Boss digital delay) as when it's plugged into the FX-Reverb unit.
In other words, the passive effects loop with the delay seems to need a CF in front of it.
So, my thinking is why not install a CF on both the clean and the OD channels?  Geezer has been kind enough to interact with me around this idea in using a Mosfet on the clean channel to accomplish this.
I am probably going to build the mini-TOS (which I am excited about) & have been looking at some options here.
Geezer drew up a "switchable" CF so that the OD tone is unaffected by a CF on the clean channel.
Some thoughts on these two designs?
Think the switchable mosfet design would work?    Any noise issues that you'd caution about?
« Last Edit: May 20, 2011, 05:55:26 am by tubenit »
Re: Mosfet CF and mini-TOS
« Reply #1 on: May 20, 2011, 10:55:22 am »
tubenit, I like the second one
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: May 21, 2011, 09:36:41 pm »
Tubenit - I think you need a gate stopper resistor for the MOSFET cathode follower.
Respectfully,
Chip
Quote from: jjasilli
Quote from: PRR
Offline Geezer
« Reply #3 on: May 22, 2011, 05:50:42 am »
Respectfully,
Chip
I agree....what, a 100R? 220R?
I am working on putting this preamp into a PP 6BM8-type amp.....
EDIT: Keen suggestes a 220R here>
http://www.diystompboxes.com/smfforum/index.php?topic=73669.0
« Last Edit: May 22, 2011, 06:03:37 am by Geezer »
« Reply #4 on: May 22, 2011, 07:08:53 am »
Q1:   What is a gate stopper????   Can you show one in a schematic, please?
Q2:   What wattage of a gate stopper resistor?  Would a 1/2 watt work?
Q3:   Does the mosfet need to be anchored on to the chassis like in a VVR or can it be mounted on a layout board?
Thanks for the help!  With respect, Tubenit
« Reply #5 on: May 22, 2011, 09:25:16 am »
Here's some interesting reading of a thread that's used mosfet replacing tube stage(s) to get a feel for what you're working with...hope this helps in your quest guys.
http://music-electronics-forum.com/t3509/
« Reply #6 on: May 22, 2011, 09:37:42 am »
Hi tubenit
You need a 100-200R (1W) resistor in series with the gate of the IRF820, and you possibly also should have a ~12V zener between the gate and the source (cathode/banded end pointing at the gate). I've had to do this with a mosfet source follower when I've used them in trem circuits a couple of times now. (Schematic attached - the source follower is in the trem circuit)
I mount my ones on a bit of perf board.
« Last Edit: May 22, 2011, 09:42:19 am by tubeswell »
Offline Tone Junkie
« Reply #7 on: May 22, 2011, 12:18:43 pm »
You guys really think of some cool stuff, made my day, taught something good once again.
Thanks Bill
                                  :happy1: :happy1: :happy1:
   sorry these things remind me of my kids
« Reply #8 on: May 22, 2011, 04:54:09 pm »
Thanks for the replies.
As I am understanding it, the mosfet could be mounted on the layout board (since a perf board has worked)?
Thank you for the help!  It is appreciated.
« Reply #9 on: May 23, 2011, 01:43:25 am »
The zener is also a good idea in a source follower application, and I only learnt that about 6 months ago
http://music-electronics-forum.com/t18452/
« Reply #10 on: May 24, 2011, 05:21:05 am »
I drew up a layout to go with the schematic. They're editable and in the SCH library.
http://www.el34world.com/Forum/index.php?topic=11607.new#new
Offline chocopower
« Reply #11 on: May 24, 2011, 11:16:57 am »
Just for share it.
First i tried a IRF830, but the high capacitance was a problem. Them i use a ZVN0545A. Great and easy tweak!!
« Last Edit: May 24, 2011, 11:22:10 am by chocopower »
David
« Reply #12 on: May 24, 2011, 12:18:24 pm »
Just for share it.
To understand the objective - is this to lessen the load created by the hi output impedance together w/ the signal load of the tone stack thereby preserving the gain from the previous stage(s)?
Also, does it help w/ the frequency response and/or tone too?
Offline Geezer
« Reply #13 on: May 24, 2011, 01:04:58 pm »
What were the symtoms of the IRF8__ mosfet high capacitance problem?? Loss of highs?
Offline chocopower
« Reply #14 on: May 24, 2011, 01:08:39 pm »
Yes.
even with the ZVN i have to put a 4,7uf cap in the 820 rk for a more bright sound. A bypass cap for the volumen pot is a must too.
David
Offline chocopower
« Reply #15 on: May 24, 2011, 01:10:28 pm »
Just for share it.
Sorry. Your question is far away up for my technical and english level.... :help:
David
« Reply #16 on: May 24, 2011, 01:17:16 pm »
Thanks Chocopower for the information!
Chocopower was referencing an IRF830.  I plan to use an IRF820.  I don't know if that makes any difference or not.  Data sheet is here:
http://www.mouser.com/ProductDetail/Vishay-Siliconix/IRF820PBF/?qs=sGAEpiMZZMsdSsOhgyFDi%252b36OT01M0HUhI%2fjewLPBDo%3d
Offline chocopower
« Reply #17 on: May 24, 2011, 01:35:09 pm »
I suposse the output capacitance is the trick.
120pf for the IRF830
61pf for the IRF820
10pf for the ZVN0545A
David
« Reply #18 on: June 10, 2011, 11:41:59 am »
I got a 12v zener  with 21ma  & 1w rating.
Will that work to protect the mosfet?
« Last Edit: June 10, 2011, 11:56:51 am by tubenit »
Offline Tone Junkie
« Reply #19 on: June 10, 2011, 02:21:08 pm »
I really enjoy the fact that I can just follow along with what you guys are doing and every day you teach me something new.
Thanks Bill
Offline Fresh_Start
  • noob de Lux
« Reply #20 on: June 10, 2011, 02:30:32 pm »
Simply parotting what R.G. Keen & Steve Connor have written, you should be fine with a 10-15v zener rated at 1/2 watt:
http://www.geofex.com/Article_Folders/mosfet_folly/mosfetfolly.htm
http://www.geofex.com/Article_Folders/sstremolo/sstremolo.htm (schematic showing you've got the cathode pointed in the correct direction)
http://music-electronics-forum.com/t18452/ (discussion with tubeswell on AMPAGE)
All that said, I don't see how the gate could go more than a couple of volts higher than the source with an AC coupled cathode follower MOSFET.  Looking at the second link (tremolo), there are no caps between B+ and the gates of the three MOSFETs.  Therefore, in that case, the gate-to-cathode voltage WILL be greater than 20 volts (max spec) for a moment at turn-on.  That's not the case in tubenit's circuit because there is a cap between B+ and the MOSFET's gate.  Of course, the cap theoretically could leak DC which sends us right back to the zener for protection...
Hope that helps,
Chip
Quote from: PRR
« Reply #21 on: June 10, 2011, 04:15:51 pm »
Thats some great reading Fresh Start, this got me  :think1: of a post Tone Junkie posted http://www.el34world.com/Forum/index.php?topic=11645.0. I liked the Preamp and wanted to mate it with an 18W power amp.I'm am in the planning stage and now this has got me  :think1: (waaaaaaaaaaay to much  :think1:) It has a gain stage that can be added (blackmore sw) using 1/2 12ax7,V3b but as always there 1/2 that is not used (don't like wasting TRIODES). I was wondering if this triode could be replaced with the mosfet or does it require an existing triode to be effective or could it be linked to V1b. What would it sound like? Thanks for opening a new can of worms
