August 29, 2026, 09:40:16 am
Hoffman Amps Forum image Author Topic: stereo troubleshooting advice  (Read 5585 times)
Offline firemedic
« on: May 20, 2011, 10:39:10 pm »
I've decided to try & fix the 1962 RCA Victor console stereo I just acquired, since it's in decent shape. I've replaced the paper caps, installed a grounded plug, and fired it up; AM & phono sound OK but the FM channel has very low volume. Stereo FM is even lower. I know nothing about RF amplification, so I'm gonna retube the whole FM signal. Does anyone know a good forum for dealing w/ these things?
Offline firemedic
Re: stereo troubleshooting advice
« Reply #1 on: May 20, 2011, 10:45:44 pm »
Here's the schem, Thanks PRR & dummyload!
Offline firemedic
« Reply #2 on: May 24, 2011, 05:17:43 pm »
Well it's about as fixed as I need it to be, pretty much the same troubleshooting rules. Nominal voltages, basically, are what you need to fix anything.
I replaced an open screen resistor on the FM limiter. Whatever that is.
The phono sounds fantastic (even my wife notices the tube difference), I rigged it to connect to iPod or CD player w/ a 1/8" aux jack, & the FM works OK. Done. Before the new tubes even got here.
« Reply #3 on: May 24, 2011, 06:01:52 pm »
congrats.   :icon_biggrin:
--DL
« Reply #4 on: May 26, 2011, 12:48:12 am »
To get FM you want a clipped signal. (You only want transmitter "pitch", not "loudness".) You do this by running a pentode at low screen voltage. If resistor is open, screen voltage is zero, signal level is clipped to zero, and that don't work at all (except by sneak paths).
Hoo-ray for finding the fault.
