August 29, 2026, 10:30:44 am
Hoffman Amps Forum image Author Topic: Bassman Head Problem  (Read 4764 times)
Offline bluebird
« on: May 23, 2011, 05:08:03 pm »
Hello from france Everbody!
I'm restoring a bassman head (blonde circuit but with a diode rectifier not a gz34)
i replaced all the electrolytics, power filter caps, power supply resistors, bias cap....cleaning all pots, switches... and  sometimes when i switch the stand by the amp has only 160-165v on the phase inverter 100k resistors instead of 300-305v. When it warms up the voltage becomes ok again and the sound is ok again too...it's a mystery, if someone got a idea it would be cool!!
many thanks
hervé
more info : i have 445-450v out of the diode rectifier, negative feedback is ok at -56v.
Offline blues man
  • I hate solid state amps
Re: Bassman Head Problem
« Reply #1 on: May 25, 2011, 08:12:41 pm »
I would check your solder joints and that part of the power supply that feeds the phase inverter. If you didn't replace all the caps I would definitely be checking them. you could have a bad resistor that changes values after the amp heats up. Did you check the resistor values when you pulled the caps to replace them. This is a good time to do so. Change the phase inverter tube and see what happens. These are just ideas.
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #2 on: May 26, 2011, 11:22:53 am »
how long of a time period is it between turning on the amp that you are getting this 160 to 165v on the PI, the tubes do have to warm up .
Offline phsyconoodler
« Reply #3 on: May 26, 2011, 12:00:46 pm »
Quote:"negative feedback is ok at -56v."
You must mean BIAS voltage.  Indeed recheck you filter cap solder joints,especially the ground side.
