September 15, 2026, 01:12:24 am
Hoffman Amps Forum image Author Topic: Mini-TOS OT wiring  (Read 8060 times)
Mini-TOS OT wiring
« on: May 27, 2011, 09:45:14 pm »
I am going to use a single ended OT for the mini-TOS with the 6BM8 pentode.
8W to 12W SE Guitar Amp Output XFMR
82Hz to 10KHz, 60mADC
7000 Ohm and 5000 Ohm inputs to 4/8/16Ohm Outputs
The 6BM8 tube data is:
Pentode Class A AmplifierPlate Voltage ................................. 200 VGrid No. 2 Voltage ............................ 200 VGrid No. 1 Voltage ............................ -16 VPeak Grid No. 1 Voltage........................ 6.6 VAmplification Factor .......................... 9.5Plate Resistance (approx) ..................... 20K ΩTransconductance .............................. 6400 µPlate Current ................................. 35 mAGrid No. 2 Current ............................ 7 mA
Load Resistance ............................... 5.6K Ω
Power Output (approx) ......................... 3.5 WTotal Harmonic Distortion ..................... 10 %
So, am I approaching this correctly to use the 5000 ohm primary to the 8 ohm speaker?
Thanks, Tubenit
Re: Mini-TOS OT wiring
« Reply #1 on: May 28, 2011, 08:26:43 pm »
What B+ are you expecting to have?
V^2/7W = trial value of SE pentode impedance.
« Reply #2 on: May 29, 2011, 01:48:56 am »
Sorry ...
do you mean (V x V) / 7W  -  (the square of the voltage divided by the wattage) ??
Kagliostro
« Reply #3 on: May 29, 2011, 06:09:51 am »
B+ will be 277 volts on the 6BM8 plates.   I apologize but I've had no training in electronics & I don't understand the formula you liste?
with respect, Tubenit
« Reply #4 on: May 29, 2011, 06:23:47 am »
That is just a basic power formula that has been shuffled around to solve for R (resistance)
Resistance is voltage squared divider by power....   R = E^2/P
Using your voltage and PRR's 7 watts yields 10.9K for plate resistance.
« Reply #5 on: May 29, 2011, 07:03:46 am »
I am thinking 6BM8 single ended will be 3.5 watts?
277 X 277 =  76729  divided by 3.5 wattage = 21.9k for plate resistance
Not sure how to hook this up now???    I'll be using a 8 ohm speaker.
What should I hook up for the primary?
What should I hook up for the secondary?
Help please!   With respect, Tubenit
Offline Geezer
« Reply #6 on: May 29, 2011, 07:52:41 am »
The most you're going to get from the primary using your 8ohm speaker is 14k (7k primary using the 4ohm 2ndary tap)
I think you're going to need to temp tag the OT in and try different taps (starting with above mentioned one) & see what sounds "right" to your ears(?)
G
« Reply #7 on: May 29, 2011, 12:41:38 pm »
no, the 7W is the TOTAL dissipation of the tube, you will only be able to deliver 45% (about 3.5W) of that at best to the load.
formula is Va2 x Pdiss (Total Plate Power Dissipated)
in your case, 8K would be best.
datasheests also say @ ~270V use 8K  - see pg. 4 of link below.
http://tubedata.milbert.com/sheets/010/e/ECL82.pdf
Offline Geezer
« Reply #8 on: May 29, 2011, 02:41:42 pm »
So 7k/8ohm is going to be your closest bet.........
G
« Reply #9 on: May 29, 2011, 10:41:57 pm »
That is much higher than the 200V suggested condition.
The tube can only take so-much heat. 7 Watts.
Output, perhaps. But first we want to get the power INPUT near-but-not-over the 7 Watt rating.
If you INcrease voltage by 270/200 or 1.35 times, to avoid meltdown you must DEcrease current by 1.35 times.
Suggested 200V 35mA becomes 270V 26mA.
Check: 270V*0.026A= 7 Watts, OK/safe.
Now as a -rough- starting point, pentode load should be the ratio of V/I.
270V/0.026A= 10,385 ohms.
+/-30% variation will cause small change of Power and some change of flavor.
If you have a low-pay helper who will do tedious work well, try all variations and see which numbers you like best. ECL82 curves are fairly soft, the V/I guesstimate for load impedance doesn't give the "very best" numbers, but the difference must be slight.
Use the 7K tap.
« Reply #10 on: May 29, 2011, 10:59:43 pm »
datasheets do suggest a 270V condition.
--DL
Offline andrew_k
« Reply #11 on: May 29, 2011, 11:30:50 pm »
I'm using 7.5K:8ohm OTs from Epiphone Valve Jnrs (series 1 and 2 shipped with these, series 3 onwards uses 5k:8ohm) for a 6BM8 stereo and they sound excellent. Very happy with that combination. B+ is just shy of 300V. hope that helps.
« Reply #12 on: May 30, 2011, 05:53:27 am »
I am seeing the maximum voltage ratings  (design center values) in the tube data being:
PentodePlate Voltage ................................. 600
VGrid No. 2 Voltage ............................ 300 V
http://www.nj7p.org/Tube4.php?tube=6bm8
I ran my Little Wing and my 56T amps with 6BM8 tubes at 305 volts with no issues at all.
I appreciate all the help!  Thanks,  Tubenit
« Reply #13 on: May 30, 2011, 09:29:18 pm »
Tubenit was attempting to use a 200V condition. If that is the only suggestion available, you can extrapolate: 1.35 times voltage means 1/1.35 times current and 1.8 times load impedance. 8.3K.
The 272V condition suggests 8K load, which is indeed what Tubenit should be looking at.
The "Va0 = 600V" number is for _NO_ current. Inside a TV set, some strange things can happen during turn-on. The "Va = 300V" number is an operating limit.
But WHY should you run at MAX voltage? In SE it does not affect Power: output power is usually limited by Plate Dissipation. A wide range of B+ voltages give nearly the same power output. 200V: 3.3W, 272V: 3.5W. This assumes you scale the load impedance to the actual voltage and current you use.
For 270V in a 7 watt tube, get in the ballpark of 8K. 7K is plenty close enough.
« Reply #14 on: May 31, 2011, 05:07:59 am »
PRR & others,
Thanks for the help!
