September 14, 2026, 10:21:08 pm
Hoffman Amps Forum image Author Topic: OT Layout Help  (Read 5032 times)
Offline J Rindt
OT Layout Help
« on: May 30, 2011, 01:16:35 pm »
Wondering if I can/should keep this OT where it is. Just kind of wondering about the proximity of the Input Jack to the OT. If I am careful/creative with lead dress, is it likely to be a problem.? You need to Open the attachments to see the whole picture.
Thank You
« Last Edit: May 30, 2011, 01:18:47 pm by J Rindt »
Offline phsyconoodler
Re: OT Layout Help
« Reply #1 on: May 30, 2011, 01:19:41 pm »
shielded cable should make it ok.Are you re-using the switch-mode power supply? Bad idea.They are problematic in Crate amps.
Offline J Rindt
Re: OT Layout Help
« Reply #2 on: May 30, 2011, 01:57:55 pm »
Thanks for the good news  :think1:
Yeah, I was planning on using that S.M. Supply. I had originally planned on using a PT from a Fender Deluxe Rev, but the primaries are burned up. So.......I thought I would just use that existing Power Supply.
So these Crate S.M. Power Supplies are problematic you say.....?
OK....so now I am in the market for a PT again. Was just kind of wanting to do this "On The Cheap".
Thank You
« Last Edit: May 30, 2011, 05:57:27 pm by J Rindt »
Re: OT Layout Help
« Reply #3 on: May 30, 2011, 05:32:16 pm »
The problem is that the power supply can shut down if the amp distorts too much.It's built in protection feature of the PS.They don't like fluctuations in voltage and tube amps fluctuate when the tubes demand more current.
  It may be why most tube amps don't use a SM power supply.they are usually only found in solid state and bass amps.
