August 29, 2026, 10:30:47 am
Hoffman Amps Forum image Author Topic: Volume boost  (Read 9197 times)
Offline macula56
  • welcome to the bootyranch
Volume boost
« on: June 15, 2011, 08:27:31 am »
I want to boost the volume in an amp.  I'm trying to find a schematic that would point me in that direction. Something with perhaps 1/2 a 12AX7 into a volume control then into the other half of the 12AX7 and then into a CF then tone control. Can anyone point me to a good schematic? I see lots with standard Fender style stuff and Marshall style. I haven't had any luck with this type as far as schematics. Thanks, JMac.
Offline phsyconoodler
Re: Volume boost
« Reply #1 on: June 15, 2011, 10:12:14 am »
Try this:
Offline macula56
Re: Volume boost
« Reply #2 on: June 15, 2011, 11:10:56 am »
having zero experience with the cascode stuff, what are the benefits of these circuits? are they better than plate fed into the next stage?
Re: Volume boost
« Reply #3 on: June 15, 2011, 12:23:59 pm »
They don't have huge gain,which may be too much when you just want a volume boost.
  Also take a look at Mesa's Solo circuit on the Lonestar amps.they use the effects loop to add a solo boost to the amp.
there are other ways to just add a 'boost' in volume at lower amp settings without adding too much gain.Try a .05uf across the existing volume pot.It does add gain but not necessarily distortion depending on your amp.
  Then you can have a negative feedback lift switch.
It depends on what you want happening with the volume you seek.Sometimes a good EQ pedal in front of your amp gives you what you need without the added circuitry.
  Lots of options.
Offline macula56
Re: Volume boost
« Reply #4 on: June 15, 2011, 12:48:48 pm »
i thought about adding an extra stage like some of the Bassman's. i just want a little volume boost. thanks Psycho.
Offline jerrydyer
  • Make it one of a kind
Re: Volume boost
« Reply #5 on: June 15, 2011, 03:34:03 pm »
how about a simle tone stack defeat boost. using a vactrol etc?  I love that type of boost it seems to be the perfect bump for whatever level im playing at.
Offline Tone Junkie
Re: Volume boost
« Reply #6 on: June 15, 2011, 09:12:44 pm »
So Jerry do you have an example of a tonestack defeat switch we could look at or directions to were we could see it on an amp schematic.
Thanks Bill
Offline macula56
Re: Volume boost
« Reply #7 on: June 16, 2011, 05:22:23 am »
the tone defeat is not what i am looking for but thanks Jerry.
Offline jerrydyer
Re: Volume boost
« Reply #8 on: June 16, 2011, 10:43:15 am »
what about two volumes or two master volumes.  or is it that you also want a little gain boost?
for tone junkie  its just removing the tone stack ref to ground off the mid pot. you can use a mechanical switch (front panel) or if you know how to wire up a vactrol or relay, you just add or subtract the ground to the tone network.
Re: Volume boost
« Reply #9 on: June 16, 2011, 12:26:49 pm »
The problem w/ a tone stack lift is that the signal easily gets muddy from too much bass especially at high volumes. So you have to account for that w/ a smaller coupling cap from the prior stage and/or a small bypass cap also. Or you can make a simple high pass filter network or similar. Then it will sound good and be useful/practical.
Offline Tone Junkie
Re: Volume boost
« Reply #10 on: June 16, 2011, 09:58:26 pm »
So if you use the tone stack lift you need to dial in a way to take out the extra bass with the other side of the switch. possibly adding a gain stage with just enough boost for the lead channel might be a better way to go.
Thanks Bill
Offline macula56
Re: Volume boost
« Reply #11 on: June 17, 2011, 05:27:25 am »
We're getting away from my original question folks. I am not looking for a solo boost or anything to do with lifting the tone control ground. i am looking for a schematic that has a overall volume boost after a volume control and before the tone controls. if anyone can point me to a schematic like that i would greatly appreciate it.
Re: Volume boost
« Reply #12 on: June 17, 2011, 07:35:56 am »
Here's a simple but effective boost. Replace the 470K with a pot if you want a boost level also.
Re: Volume boost
« Reply #13 on: June 17, 2011, 08:07:38 am »
If you are willing to expand your approach ...................  you can get a volume boost with these.  Also with Geezer's Tweed Overdrive Special, he used a 12AX7 triode for a "FAT" control that does increase the volume.  It's in the SCH library.
You can also use a SPDT to switch in a lower value 12AX7 cathode resistor with a high value cathode cap.  In the schematics file there is a  "Switches, bells and whistles" thread with numerous ideas.
http://www.el34world.com/Forum/index.php?topic=5621.0
« Last Edit: June 17, 2011, 08:10:52 am by tubenit »
Offline macula56
Re: Volume boost
« Reply #14 on: June 17, 2011, 08:09:32 am »
many thanks Sluckey and Tubenit. i will try these ideas when i get home.
Offline jerrydyer
Re: Volume boost
« Reply #15 on: June 17, 2011, 12:38:54 pm »
dual volume's  or masters,  similar to that switch bypassing the 470k res .
Offline Tone Junkie
Re: Volume boost
« Reply #16 on: June 19, 2011, 09:48:34 pm »
The trim boost on the blusemiester is a good one here is another .
Bill
Offline Tone Junkie
Re: Volume boost
« Reply #17 on: June 19, 2011, 09:51:01 pm »
Sorry the picture didnt work well I will fix this when i get back home.Bill
Offline Tone Junkie
Re: Volume boost
« Reply #18 on: June 20, 2011, 01:28:34 pm »
macula56 I know these were not what you were asking for i couldnt find anything like that in just a plain control but here is solo boost that if not helping you might help someone else.
thanks Bill
