September 14, 2026, 04:22:32 pm
Hoffman Amps Forum image Author Topic: Need a tech lesson-How to read the tube datasheet-can you give your contribute ?  (Read 14291 times)
Please I need a technical lesson
I would like to learn how to understand more the data on tube datasheet
have you a link for that or can you give news as to correctly afford the read of a datasheet ?
Many Thanks
Kagliostro
A couple of members, including Butterylisciuos, gave some great tutorials (to me among others) on load lines.   :worthy1:   I can't find the thread(s).   :dontknow:    Maybe someone will remember.  :think1:
Meanwhile, what specifically do you want to address?   :dontknow:  Usually the first hurdles are the max ratings, then tables of typical operation.  Then there's the dreaded tube curves.   :BangHead:
Offline Fresh_Start
  • noob de Lux
What are you trying to figure out?
Here's the best tube data search I've found:
http://www.mif.pg.gda.pl/homepages/frank/vs.html
Enter 6L6, then select the G.E. 1963 sheet for a 6L6GC.
The "Maximum Ratings" are always useful.  On some older data sheets, they refer to "Design Center Maximum" IIRC.  It's not quite the same thing, and I think the "Design Center" figures typically are lower.
On page 2, it shows typical operating conditions.  A treasure trove of good info!  Unfortunately, the supply voltages tend to be lower than what you find in modern amps.
Then you hit the graphs.  I still have a hard time understanding these because they typically show 3 variables at the same time.  Merlin a.k.a. "Valve Wizard" has great info on using the graphs HERE for triodes.  His pentode section isn't about power tubes, but helpful:
http://www.freewebs.com/valvewizard/pentode.html
I used to have a link to an essay called "Understanding Load Lines" but can't find it.  Anybody else familiar with it?
Hope this helps,
Chip
« Last Edit: June 16, 2011, 02:40:40 pm by Fresh_Start »
Quote from: jjasilli
Quote from: PRR
Offline triode
  • Use the silver solder
    • TheAirtightGarage
PRR has a way of presenting things to people that make it easy to understand. I was reading a
thread of his a while back and thought some other people would find it useful at the time...
so I asked PRR if I could recreate this thread in a pdf this a few years back, he said ok, so here it is again...
LoadLinesbyPRR...
http://theairtightgarage.com/gallery/loadlinesbyprr.pdf
Offline Fresh_Start
  • noob de Lux
LoadLinesbyPRR...
Many thanks to Triode and PRR!
Quote from: PRR
Many thanks to all for the given advices and infos
those are two things that I would like to understand better
Many thanks also for the given links with first class infos
Kagliostro
Offline simonallaway
    • Hot Bottles - Tube Amp Blog
The opening chapters of Merlin's book on pre-amp design is very good on how the curves relate to the circuit. As a newbie I got a lot out of it.
Offline Fresh_Start
  • noob de Lux
Merlin is nice enough to provide the entire first chapter of his preamp book here:
http://www.freewebs.com/valvewizard1/Common_Gain_Stage.pdf
That's what I intended to link to in my earlier post, and it is good albeit without the stained napkin in PRR's discussion :wink:
Chip
Quote from: PRR
