August 29, 2026, 10:32:29 am
Hoffman Amps Forum image Author Topic: alternate EF86 pentode?  (Read 26594 times)
Offline phsyconoodler
« on: June 20, 2011, 04:46:19 pm »
Is there any pentode that can replace an EF86 and do it's job without added gain?
  I'm waiting for an EF86 to complete a job but was wondering if there was an alternative.
Re: alternate EF86 pentode?
« Reply #1 on: June 21, 2011, 01:25:22 pm »
anyone have any experience with a 6EJ7? They look interesting.
« Reply #2 on: June 21, 2011, 01:47:22 pm »
I'm not sure if I remember well
may be ef83 ??
Kagliostro
« Reply #3 on: June 21, 2011, 03:18:48 pm »
E80F is a pin-for-pin substitute, and according to some reports on other forums is a damn fine audio tube. When I find one to try, I'll report back
« Last Edit: June 22, 2011, 01:03:22 am by tubeswell »
« Reply #5 on: June 21, 2011, 03:45:03 pm »
6BR7
i was looking into building a stomp box - check out the 6AJ5.
--DL
« Last Edit: June 21, 2011, 03:48:51 pm by DummyLoad »
« Reply #6 on: June 21, 2011, 09:55:26 pm »
Are you simply curious about other pentodes to try or something that fits in the same 9pin socket w/out re-wiring? Sorry, I'm not sure what you're looking for exactly?
Offline RicharD
    • Toxic Water
« Reply #7 on: June 21, 2011, 10:00:30 pm »
I don't know of a direct replacement for the EF86.  The 6SJ7 tends to perform similarly.  Phsyco mentioned the 6EJ7 which looks like an EF86 at a glance.  I've been meaning to experiment with these since I have a baggie full of them.
« Reply #8 on: June 21, 2011, 11:09:53 pm »
I've had nice success w/ this little ol' 6ak5/ef95/5654 and it has worked beautifully for me. Since it's a very rugged anti shock/anti vibration tube I've had no microphonic issues and it's readily available and cheap. I haven't pressed it into a bunch of different applications at this time but it sounds good to me and compares favorably to both the 6267 & 5879 so far as I can tell in a SE amp.
« Reply #9 on: June 22, 2011, 10:15:57 am »
I found an EF806s/6267 tube in my stash.Is this the same as an EF86? I can't find any matches in the tube sub charts.It was in an old amp that I gutted years ago.
« Reply #10 on: June 22, 2011, 10:47:16 am »
Hi phsyconoodler. See my earlier post.
« Reply #11 on: June 22, 2011, 11:49:07 am »
I popped in the tube and fired up the amp.It sounds lovely! No smoke,no noises and lovely chimey gutsy sounds.
  This is likely an Amperex made in Holand 6267 tube.
  One thing that's puzzling is it tests shorted on my tube tester when set to the EF86 setting but tests fine on the 6267 setting???
 My first foray into pentodes for use as preamps has been successful.
   Sweet-ass tone and tons of gain too!
Tubeswell,you mentioned the E80F.That one looks interesting.
Offline Tone Junkie
« Reply #12 on: June 22, 2011, 01:56:38 pm »
Phsyconoodler did you use it with the standard ef86 values, I guess the correct question you didnt change anything right.
Thanks Bill
« Reply #13 on: June 22, 2011, 02:15:52 pm »
Yes - sorry I forgot to post a handy link explaining the E80F (which AFAICT is a Mullard hi-spec version of the EF80)
http://r-type.org/exhib/aaa0486.htm
« Reply #14 on: June 22, 2011, 02:36:11 pm »
I used the exact values for an EF86 and it works perfectly.
  I can't make head nor tails of those tube data sheets! I see an amplification factor of 20 and that tells me it doesn't have the gain of an EF86 so I can't use it.
  I'm basically only interested in a pentode that has enough gain to be comparable to the EF86 and just uses the rotary tone dial.They are easiest to implement into an amp.Simple is good in my book!
« Reply #15 on: June 22, 2011, 05:17:25 pm »
EF806S/6267/EF86 are the same tube electrically and pin compatible, EF40 is the predecessor that uses a 8pin rim-lock socket.
E80F is pin compatible, has slightly less slope and g2g1 mu is 25 (EF86 is 38). this tube appears to be electrically similar to the 5879.
EF83 (6BK8) is pin compatible to EF86, however, it is a vari-mu tube. NOTE: shady fleabay sellers are trying to pawn these off as an EF86 replacement. they are NOT an EF86, as the EF 86 is a sharp cut-off pentode.
E804S - electrically similar to EF86 with different noval pinning with slightly less filament draw. it is a hi-reliability long-life tube.
EF85 electrically similar characteristics to the 6AU6 in noval pinning. EF94 is electrical and pin equivalent to the 6AU6.
Brimar 6BR7 seem to be nice AF tube, electrically similar to EF86, but is not pin compatible. still obtainable for reasonable (~15USD) scratch.
-DL
Offline Shrapnel
« Reply #16 on: June 23, 2011, 12:15:01 am »
I see the 6267 replaceable by: 8D8, 6F22, EF86, EF87, EF806F, M8195
AS per SAM'S TUBE SUBSTITUTION handbook 8th edition(TUB-8), 1964
-Later!
« Reply #17 on: June 23, 2011, 10:43:24 am »
Thanks for the list. I also found these subs: CV10098,CV2901,Z729
