September 16, 2026, 07:45:30 pm
Hoffman Amps Forum image Author Topic: '3 Monkeys Orangutan' amp  (Read 15882 times)
Offline RobBozic
« on: June 23, 2011, 06:58:36 am »
Hi guys,
I was internet browsing & saw this amp from '3 monkeys amps' (http://www.3monkeysamps.com) called the 'Orangutan' and on the website there's a gut shot of the amp & a description. To me it looks like an early 70's Orange clone. The amp sounds killer.
The topology looks to be Gain stage - James TS - Gain stage - 6 Position rotary switch - Gain stage - AC Cathodyne PI - 4 x 6V6 Fixed bias (No NFB), with reverb in parallel with rotary switch.
I was wondering if anyone has built a clone or owned an early '70's Orange amp. If so, do they have any comparisons with typical Fender or Marshall amps.
I'm thinking of building a clone without reverb.
Rob
Re: '3 Monkeys Orangutan' amp
« Reply #1 on: June 23, 2011, 08:22:38 am »
Orangutan = Orange!  However, the "clean" Fender guitars, strat & tele, do not sound clean to me.  I guess for clean tone, I'm a Fender guy.
Offline rzenc
  • TUBES RULE
« Reply #2 on: June 23, 2011, 10:12:57 am »
I built both versions, A.C. coupled cathodyne and D.C. coupled cathodyne. Both amps are very nice. A.C. coupled reminds me of some tweedish tones... if you excuse the comparison it might be a big bad 5E3 -  D.C. coupled has more humpf. Changed from EL34 to 6L6 then to 6550 to deal with headroom. Both versions are really touch sensitive. I had not tested them with Celestion GreenBacks - AFAICT, Orange/Matamp used them inside 4x12" cabinets.
I think they are fine rock'n'roll tone machines, but not really for clean stuff, IMHO.
Final version:
I dropped the cathodyne P.I. and installed a LTP; Inserted a post EQ drive section; minor tweaks. Fooled around with pentode/triode switch; cathode bias/fixed bias switch.
Here is a pic off of an amp I built based on these concepts RZC Reaper 80.
With Respect
Best Regards
Rzenc
Offline RobBozic
« Reply #3 on: June 23, 2011, 09:45:00 pm »
Hey 'Rzenc' is there any particular schematic you followed, or is there a schematic you tweaked yourself?
Also was the DC cathodyne PI smoother than the AC Coupled?
Offline rzenc
  • TUBES RULE
« Reply #4 on: June 24, 2011, 10:27:00 am »
See attached schem. It's a 4x6L6GC output power section. Preamp is basically ORANGE GRAPHIC MKII (1972), dropped rotary switch and installed a 'shape'. Also changed split load P.I. to LTP. Beefed up power supply. It's the schem of the amp I posted the above pic.
I would not say smoother, but rather more agressive - too much for what I was looking for -.A.C. reminded me of a bigbad 5E3. Both sounded very nice. LTP made it happen to me.
If you don't mind my saying so, AC would be more of classic rock/blues tones. DC sounded more like a hot rodded marshall....
Hope this helps
With Respect
Best Regards
Rzenc
Offline theleftfoot
« Reply #5 on: October 27, 2011, 01:53:11 am »
hey Rzenc
is this an eagle file? i can't open it!
can you upload it again? or maybe pdf?
thanks in advance
raffa
Offline Geezer
« Reply #6 on: October 27, 2011, 05:54:05 am »
hey Rzenc
thanks in advance
raffa
It's an "express schematic" file.....you need a specific (free) program to view & edit.
Download here> http://www.expresspcb.com/expresspcbhtm/Download.htm
In the meantime, pdf copy attached
« Last Edit: October 27, 2011, 05:59:08 am by Geezer »
Offline theleftfoot
« Reply #7 on: October 27, 2011, 06:31:07 am »
thank you very much for the clarification!
@Rzenc; the amp looks awesome!
what kind of transformer did you use? 470V for the first stage is very high!
did you have sound sampler or vid?
would be interesting to use it with el84...
thanks for the answer
cheers raffa
« Last Edit: October 27, 2011, 07:02:52 am by theleftfoot »
Offline rzenc
  • TUBES RULE
« Reply #8 on: October 27, 2011, 07:38:17 am »
Hi Raffa,
This amp was a Laney GH100L. I used the irons and chassis and cabinet to build it... stripped it down, painted the chassis white, new function layout, took the front cab cover sub for Imbuia - maybe something close to walnut to you??? -
Long story short: the owner is a long time friend and believer of my work  :l2: and helped me with the development of this amp.. he plays 4-5 times week on very big arenas - with one of Brazil's biggest shots on pop/country scene...he took the original amp to the road and it endured around 2-3 years of road abuse...the only bad thing that happened was a broken glass on one of the 6550's. P.A. man loved the amp and talked to my friend to never let it go.. well he decided to change the insides of the laney as well as cosmetics too.  :icon_biggrin:
The amp has gone thru some minor mods now - which I need to update on the schem... changed from fixed to cathode bias, made some changes on the P.I. and preamp too.
Sorry, no videos yet...but I have some samples which I can send to you... pm me...
Althought I haven't build it using EL84, I don't know how 84's will stand the voltages. P.I. is able to kick 6550 to full tilt and some.. I believe 84's might have a bad time with much drive from P.I.
Best regards
Rzenc
Offline theleftfoot
« Reply #9 on: October 27, 2011, 08:16:14 am »
cool story,
must be diamond of a amp!  :worthy1:
yeah I'm interested in the soundfiles...send you a pm
would be great if can update the schema...think will clone you ! :l2:
thanks mate raffa
Offline rzenc
  • TUBES RULE
« Reply #10 on: October 27, 2011, 10:33:47 am »
cool story,
thanks mate raffa
Thanks man!
If you are interested in building it, I can update them schem for the 6550 version, which is up and running for about 5 years. It has a couple of other stuff too, pentode/triode, fixed/cathode switches and to my liking sounds 'better' than the 6L6 version.
Be advised that it's a loud, heavy beast  :guitar1
Best Regards
Rzenc
Offline theleftfoot
« Reply #11 on: October 27, 2011, 10:48:17 am »
jaman Rzenc,
do this! update the schematic please!
i have my workplace ready!
raffa
Offline theleftfoot
« Reply #12 on: August 28, 2012, 03:43:07 am »
hey Rzenc
i'm still waiting for your updates?  :icon_biggrin:
any news ?
still very impressed...
raffa
Offline TubeGeek
    • Glacier Amps
« Reply #13 on: August 28, 2012, 03:16:50 pm »
This is all very interesting to me as I am about to clone a series 2000 MATAMP.
I am not an informed person on orange/matamp/green/electric circuitry but I am excited because it's different than the norm of fender, vox, marshall etc.  I've built many of those and I want something different to do.  I need a challenge. :l2:
I'll be watching this thread as your project begins and hopefully comes together.
Offline BarryW
« Reply #14 on: November 09, 2012, 06:51:34 am »
I'm interested in this one as well - if anybody plays with this design, please report back!
Offline rzenc
  • TUBES RULE
« Reply #15 on: November 09, 2012, 10:47:20 am »
I'm working on a new version of this amp...probably will be firing it up on december/january...
PM me whether you want updates on schems or soundclips.
Best Regards
R.
Offline Tone Junkie
« Reply #16 on: November 09, 2012, 04:45:25 pm »
Both, Im more interested with some soundclips but its differant I like looking at differant schematics also. My next couple builds will be dumblish style, havn't been chugging them out like used to.
 My music room is getting full just added a 6v6 bluesreck .
Thanks Bill
Offline Tone Junkie
« Reply #17 on: November 10, 2012, 02:26:50 am »
What  I would really like to see is a some schematics with a DC cathodyne and AC cathodyne PI any suggestion on schematics.
Thanks Bill
Offline rzenc
  • TUBES RULE
« Reply #18 on: November 10, 2012, 06:23:41 am »
Thanks Bill
Check EL34world schem library under Orange MK197x series of amps.
AC cathodyne
http://www.el34world.com/charts/Schematics/files/orange/orange_mkii1972.pdf
DC cathodyne
http://www.el34world.com/charts/Schematics/files/orange/orange_mkii1974.pdf
Hope this helps.
Best Regards.
R.
Offline Tone Junkie
« Reply #19 on: November 14, 2012, 01:45:37 am »
Thanks man I will give those a look.
Bill        :guitar1
Offline rzenc
  • TUBES RULE
« Reply #20 on: November 14, 2012, 10:22:55 am »
Bill        :guitar1
You are welcome!
Best regards
R.
