September 15, 2026, 02:13:29 am
Hoffman Amps Forum image Author Topic: A strange PP schematic - Mesa Boogie Mark V - How it works ??  (Read 21193 times)
Few time ago I find the schematic of the Mesa Boogie Mark V
(I posted a link in the schematic section)
yesterday eveneeng I was looking to the Power section of that schematic and I find that I can't understand it
the schematic seems to use an Ultra Linear OT, but sometime ago I've read of a guy who disassembled a M.B. MarkIV (if I'm not wrong) and that wasn't an UL OT, so I don't know for sure about the OT
as I can understand there is a switch for pentode/triode, but there are also some switchable zeners that I don't understand
other thing the tube in the bottom of the schematic is allways cathode connected to ground, his PP correspondent not
other problem are the resistors connected in grid pin5 ???
also the switch between the tubes in the middle of the schematic is confusing me
WHAT I CAN SAY ................ I'M LOST
Please need your help to understand that strange thing
THANKS
Kagliostro
Offline VMS
Re: A strange PP schematic - Mesa Boogie Mark V - How it works ??
« Reply #1 on: June 30, 2011, 02:57:56 pm »
The user manual explains the three modes of the Power Amp:
http://www.mesaboogie.com/manuals/user_manuals.html#gpm1_2
« Reply #2 on: July 01, 2011, 06:44:39 am »
Yes, OK, the function are clear
but how the circuit works ?
as example, which is the function of that zener diodes ?
I'm not able at all to understand it
Kagliostro
Offline FYL
« Reply #3 on: July 01, 2011, 08:46:06 am »
Most Mesa schemos are false.
Lower screen voltages = lower power and a different grain.
Offline VMS
« Reply #4 on: July 01, 2011, 09:14:55 am »
I also thought that there were errors but then I noticed that the wires from PI to PA are flipped.
RYSE1, RYSE2, RYSE3 and RYSE4 are for 10Watt SE mode. This mode is cathode biased with those 360 ohm resistors and the 220k grid-leak resistor is connected to ground. Screen voltages are dropped with zener diodes and 1k6/25W plate stop resistors are added.
RY100 is the simul-class switch that switches between 90Watt and 45Watt mode.
This is my interpretation but I don't guarantee it to be right.
« Reply #5 on: July 01, 2011, 01:31:46 pm »
Thanks FYL & VMS
don't know, but may be, often I've read about mistakes on the Mesa schematics
(the 1960 Davoli Krundaal italian amp schematics are full of mistakes)
OK about the purpose of those zeners
RYSE1 ... ??
220k grid-leak resistor ... do you mean 2M2 ?
what about RYTP1 & RYTP2, they act a triode/pentode mode, do you think they act simultaneously with other switch ?
Kagliostro
Offline VMS
« Reply #6 on: July 01, 2011, 01:43:50 pm »
RYSE1 ... ??
Page 7/8 on the schematic.
No.
User manual page 42 shows that channel 3 has a triode/pentode switch.
« Reply #7 on: July 01, 2011, 01:58:10 pm »
Hi VMS
Thanks for the quick replay
Kagliostro
« Reply #8 on: July 02, 2011, 02:59:03 am »
Some days ago we were talking about morphing between PP and SE
http://www.el34world.com/Forum/index.php?topic=11667.0
now there is this Mesa schematic with their PP to SE solution
I was looking to that schematic and a question comes
if after the PI we have the split of the signal how can the SE amp work ?
isn't halved the signal if we take it only from one side of the PI ?
very confused about  :dontknow:  :help:
THANKS
Kagliostro
« Last Edit: July 02, 2011, 03:04:05 am by kagliostro »
Offline VMS
« Reply #9 on: July 02, 2011, 04:24:09 am »
No, PI outputs have the same signal but so that one is inverted and the other one is non-inverted.
Here is some more info about the SE/PP switch:
http://ampbooks.com/home/amp-technology/amp-patent-7173488/
« Reply #10 on: July 02, 2011, 04:38:25 am »
Many thanks
I don't know well the matter and often I'm confused, sometimes I know something but didn't remember (I think that I'm too stressed)
Thanks again
Kagliostro
Offline VMS
« Reply #11 on: July 02, 2011, 05:54:19 am »
Hey, you're not alone, this circuit has confused me also.
I thought that if you take the push or pull tube out of push-pull you'll lose half of the waveform, but I guess it doesn't happen if the SE mode is in Class A.  :dontknow:
VMS
