September 17, 2026, 01:09:55 pm
Hoffman Amps Forum image Author Topic: This really baffles me , I wanted to measure the resistence on my champs 2.7k  (Read 4837 times)
Offline catnine
  • I am wordy and frustrating EAYOR
 NFB resister . I don't get a reading across it and I have a dpdt slide switch so i can add a 100k pot is seriers with the NBF or switch to back to the stock value. There is a schem attached . Now if I switch it to the pot position then I read 2.7K ohm .
Yes you do. It may not be what you expect, but you MUST respect reality. What does the meter say?
What is on one end of the 2K7? A 47-ohm resistor to ground.
What is on the othe end of the 2K7? The OT secondary, under 1 ohm DC.
So the 2K7 is in parallel with 47+1 or 48 ohms. The reading is something under 48 ohms, correct?
Offline catnine
yes correct. It's 46.2 ohm . I see now that it is in parallel not in series . The only way i would see the 2K7 value is if I lifted one/ either end out of the circuit .
« Last Edit: July 04, 2011, 07:59:39 pm by catnine »
Offline catnine
I understand the parallel resister reading since both ends of the 2k7 ohm NFB reister go to ground one end through  the 47 Ohm to ground and the other end through the OT coil to ground @ 1 ohm . This is what makes it parallel.
 Ok I add 1k ohm in series to the 2k7 NFB resister on the OT 1 ohm side , then I read 2k7 across the resister.
 From what I understand adding more resistence to the NFB allows less voltage back to the second gain stage so it is closer to not having NFB  a more open sound.
 Being in parallel the actual NFB value is 48 ohm and not 2k7 ohm . So and this is a question. I hear a great difference when I dial the 1k pot in series yet I am lost as to what value the NFB resistence is at that point.
 Is it 1k ohm + 1 ohm in parallel with 2k7 ohm + 47 ohm ? is it 733 ohm?
