September 15, 2026, 12:42:28 pm
Hoffman Amps Forum image Author Topic: I search the electronic diagram ZOOM FX 1000 EQ tube serie AIDEAN  (Read 19625 times)
Offline gas
Hello all
I have a ZOOM-tube amp in 1980 since my teens, I search the electronic diagram. It is down, I have burnt resistors and I do not know the value of revision and repair would be very useful
  GOOGLE net and nothing. If you have any sites or tracks on the net, thank you very
What we said is that the importer at the time was Morris, which no longer exists and that the archives were lost. If you have an idea.
MODEL IS
FORWARD TUBE SERIES
MODEL FX - 1000 EQ
SERIE A 87200
MADE IN JAPAN
By engineering AIDEAN
thank you very much
ERIC
click picture to enlargeZimage.biz
Zimage.biz
Zimage.biz
Zimage.biz
Zimage.biz
Zimage.biz
Zimage.biz
Zimage.biz
« Last Edit: July 10, 2011, 12:48:39 pm by gas »
Offline overtone
Re: I search the electronic diagram ZOOM FX 1000 EQ tube serie AIDEAN
« Reply #1 on: July 07, 2011, 10:34:24 am »
Bon Soir Eric the convict!
I think this amp was a copy of a Mesa Boogie Mk series.
And I thought that they were all transistor.
I don't think there will be a schematic for this, but apart from the spaghetti, it looks simple.
Which resistors did you burn up? Can you say or draw where these resistors are connected to?
A little drawing would be good.
best, tony
230V in Frankfurt
« Reply #2 on: July 07, 2011, 01:24:49 pm »
looks like a knock-off of a mesa boogie MkII.
some close-up pictures of the area with the burnt resistors would help immensely.
--DL
Offline gas
« Reply #3 on: July 07, 2011, 07:26:20 pm »
Merci,c'est super sympa (là j'écoute les BEATLES. Sgt. Pepper's)
Je ne suis pas en prison ,je ne suis pas un prisonnier,mais prisonnier de ma femme ,oui!
bon .
thank you, it's really good, it's great we raproche and I like it
I did all the net, the French forum
I was very young and I took the ZOOM
it's a good amp, but not at all a mki MESA, mk1 , mk2
Japan is a copy, not very good.
if you have friends on the forum is French, there must be
which is a well.
« Last Edit: July 09, 2011, 06:16:38 am by gas »
Offline gas
« Reply #4 on: July 07, 2011, 07:38:54 pm »
merci DL ET TONY
ça va sonné le zoom
Offline gas
« Reply #5 on: July 07, 2011, 07:53:35 pm »
 :dontknow:
« Last Edit: July 09, 2011, 06:15:56 am by gas »
Offline gas
« Reply #6 on: July 07, 2011, 08:18:38 pm »
I give you the INMATES IN France in public(au plan à RIS ORANGIS 1998), the sound of ZOOM is like the twin REV here is the sound that I like
http://www.megaupload.com/?d=NM2BBNN0
http://www.infoconcert.com/salle/le-plan-de-ris-orangis-416/concerts.html
RORY GALLAGUER :worthy1:
http://rory-gallagher.forumactif.net/t3-lieux-et-monuments-dedies-a-rory-gallagher
« Last Edit: July 09, 2011, 06:25:28 am by gas »
Offline gas
« Reply #7 on: July 07, 2011, 09:31:46 pm »
c'est le son du ZOOM sur le canal clair
il y a 2 guitares à gauche twin, a droite mesa boogie?.(un ampli fait maison)
Bon maintenant au travail
Ca ne sera pas facile,je vous donne les images.
mais sans le plan???
C'est un circuit bizzare
Et sans vous poussé,avec des photos ce ne sera pas facile
ZOOM is the sound of the clear channel
there are two guitars on the left twin, mesa boogie to the right?. (a homemade amp)
Right now at work
It will not be easy, I give you images.
but without the plan??
It's a weird circuit
And without getting pushed, with photos that will not be easy
Offline gas
« Reply #8 on: July 07, 2011, 09:43:03 pm »
 :worthy1:
« Last Edit: July 09, 2011, 06:14:59 am by gas »
Offline gas
« Reply #10 on: July 08, 2011, 02:44:15 am »
this is not the MK1 and MK2
http://www.guitar-pedal-repairs.co.uk/index.php?id=3&gal=1&page=7
Japanese Aidean ZOOM Mesia amp repair, re-valve, mods
(MESIA) then there was a process and then (ZOOM)
« Last Edit: July 09, 2011, 06:58:45 am by gas »
Offline overtone
« Reply #11 on: July 09, 2011, 09:35:29 am »
Yes I have seen the ones named Mesia too, but I have never seen l'impasse Rory Gallagher!
Is this the burnt resistor in your photo?
230V in Frankfurt
Offline gas
« Reply #12 on: July 09, 2011, 02:43:37 pm »
yes
and and resistance of this circuit
Zimage.biz
Offline overtone
« Reply #13 on: July 10, 2011, 01:01:07 am »
OK Eric a few more questions to help get a better picture:
You say you don't have an amp technician in the middle of France, right?
You repair cars, but do you have any experience with electrical repair, please tell us some more detail.
I can see some repairs have been made. Do you know what was done already?
Did this amp get wet or damp at some time, maybe it was outside in the garage?
230V in Frankfurt
Offline gas
« Reply #14 on: July 10, 2011, 07:26:30 am »
Hello OVERTON
it has always been in the garage to dry and safe
With the schematic, I know the repaired
I think it will be too difficult and only a technician with experience and measuring instruments can be repaired.
there was a problem with power.
amp is really a rare, may be I will find the schematic in Japan, but I do not know where to look.
thank you for your help
bonjour OVERTON
il a toujours été dans le garage au sec et a l'abri
Avec le schéma ,je sais le réparé
Je pense que ça va être trop difficile et que seul un technicien avec son expérience et des instruments de mesure peut le réparé.
il y a eu un problème avec  d'alimentation électrique.
c'est vraiment un ampli rare,je trouverai peut être le schéma au Japon,mais je ne sais pas ou chercher.
merci de votre aide
Offline gas
« Reply #15 on: July 10, 2011, 07:38:07 am »
the power supply was changed, it is the gray strength is changed.
but I do not know the original value of resistance.
Zimage.biz
I was young and I knew nothing lamps.
I gave a friend to change the power tubes and it has a bad lamps
Pair was not tested nor, I think it was that moment, as a fixed bias amp is that the failure happened.
And resistance of the power supply is burned.
Then the resistance is changed, but I think the value is not correct.
« Last Edit: July 10, 2011, 07:52:15 am by gas »
Offline overtone
« Reply #16 on: July 10, 2011, 04:05:49 pm »
I don't think you will find a schematic on the internet and you need to understand the reason why things are burning up.
I offer you this advice:
A good technician could fix this without a schematic diagram.
I think it will be easier for you to find a good technician. Ask some local guitarists who is good.
There is quite some work to do in this amplifier. After 30 years they all need some attention.
Very good luck with this amplifier!
230V in Frankfurt
Offline gas
« Reply #17 on: July 12, 2011, 05:26:45 pm »
ok thank you all and thank you overtone
I go to a technician
