September 15, 2026, 01:13:27 am
Hoffman Amps Forum image Author Topic: Cooling fan : AC or DC supply ?  (Read 8672 times)
Offline archaos
« on: July 15, 2011, 06:56:02 am »
Hi guys, all is in the title. Yet I wish to install the fan with an independent power supply ; Merlin's power supply book says that DC fan too close from the preamp can induce noise.
Thanks for your inputs, ideas, suggestions.  :worthy1:
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline LooseChange
    • Fix Your Darn Amps
Re: Cooling fan : AC or DC supply ?
« Reply #1 on: July 15, 2011, 07:42:06 am »
You don't need a fan on the preamp tubes so DC will be fine.
I made a simple DC power supply coming off the 6.3v heater supply. I ran a 12vdc fan. Since it ran at around 8vdc it ran a bit slower and was very quiet.
Call me Dan
www.fydamps.com
Offline archaos
« Reply #2 on: July 15, 2011, 08:53:17 am »
Thank you.
Mehr Licht !
« Reply #3 on: July 15, 2011, 09:44:52 am »
DC is quieter/less hum-prone
« Reply #4 on: July 15, 2011, 10:29:43 am »
Can it be as simple to just throw in two 1n4007 diodes off the heater wires and hook the fan right up to that? But then what if the heater's are raised to a higher AC voltage...? I'm guessing it wouldn't matter or would it since it's only a ground "reference" so it would still only see the 6.3DCv like the heaters?
« Reply #5 on: July 15, 2011, 10:42:08 am »
I think it you did that you would get the effect of humps from the rectified pulses going back into the ground return path
Offline phsyconoodler
« Reply #6 on: July 15, 2011, 10:51:34 am »
Old Traynor amps used AC fans that were slowed down with a big resistor.They weren't noisy,but the olf fans often fell apart after a few years,just like old fans of the day.They weren't built particularly well.A small modern 115v fan would be fine I should think.
Offline LooseChange
« Reply #7 on: July 15, 2011, 11:08:28 am »
Need to add a filter cap. Like 1000uf @ 16v (just a guess)
Call me Dan
www.fydamps.com
« Reply #8 on: July 15, 2011, 11:39:56 am »
Is there a recommended schematic or anything for a simple 4" computer fan? I have a couple laying around if I want to go this route.
« Reply #9 on: July 15, 2011, 01:01:13 pm »
Weber has a schematic on his site for hooking up a fan.
« Reply #10 on: July 15, 2011, 01:20:43 pm »
Here's how I did it.
« Reply #11 on: July 15, 2011, 01:38:11 pm »
Thanks for the schem. - I have < 40vdc applied to the heater artificial CT - do you think this will affect anything or cause something else to be needed?
Offline archaos
« Reply #12 on: July 15, 2011, 01:39:28 pm »
Which software allows to read your schematic ?
Mehr Licht !
« Reply #13 on: July 15, 2011, 01:44:20 pm »
Go here and D/L the Jschem program for your operating system
http://www.el34world.com/Forum/index.php?topic=763.0
« Reply #14 on: July 15, 2011, 02:08:12 pm »
Offline archaos
« Reply #15 on: July 15, 2011, 03:08:34 pm »
Thanks a lot guys !
Mehr Licht !
