September 14, 2026, 04:59:05 pm
Hoffman Amps Forum image Author Topic: 50 / 100 watt switch  (Read 5856 times)
Offline 67polara
  • Here is my Guild 67 polara
« on: July 16, 2011, 11:50:56 pm »
How is this accomplished?  When doing this by removing grounds to cathode the impedance will change, however I read somewhere a while back about grounding  grids to get half power with out the impedance problem.  Anyone have a circuit for that?  How does it work and is it effective?
Tony
Offline LooseChange
    • Fix Your Darn Amps
Re: 50 / 100 watt switch
« Reply #1 on: July 17, 2011, 07:56:43 am »
I have done that. Lifted the cathodes of two of the four power tubes. Works great. Stop worrying about small impedance mismatches.
Call me Dan
www.fydamps.com
« Reply #2 on: July 17, 2011, 10:26:48 am »
If I'm not wrong Geezer had some positive experiment with grounding grids of final tubes
other way is to put a potentiometer between cathode and ground in the PI tube
(I had a schematic but I'm not able to find it anymore, someone has it ???)
one other interesting way (on cathode biased amps) to lower max power is here
http://www.el34world.com/Forum/index.php?topic=4401.50
Kagliostro
« Last Edit: July 17, 2011, 12:35:46 pm by kagliostro »
« Reply #3 on: July 17, 2011, 03:06:28 pm »
I had (and still have) a very early BF Pro Reverb #138 that was "twined" in the mid to late 70's. I bought it that way. I installed a cathode-lifter switch to pull 2 of the 6L6's out of the circuit, and ran it with only two 6L6's in it for at least 15 years. Nothing to worry about.
Offline 67polara
« Reply #4 on: July 17, 2011, 08:15:39 pm »
Thank you for your answers.  Could someone show me how to wire the switch for the grid grounding one.  I think I would like to try that one instead of the cathode lift.  Do we need to sever the connection and ground the pin or do we just ground the pin?  Is a cap necessary to keep it from popping?
Tony
« Reply #5 on: July 18, 2011, 01:17:36 pm »
I think a cap will help on popping more
don't think shorting grids to ground will have a pop effect
hope someone that has do that comes here and explain we better
Kagliostro
