September 14, 2026, 02:00:21 pm
Hoffman Amps Forum image Author Topic: PS Caps?  (Read 4292 times)
Offline Frankenamp
  • What does this button do?
PS Caps?
« on: July 19, 2011, 09:56:43 am »
Hi! Got a question about power supply cap values: I noticed that Leo used a lot of 8uF and 16uF caps in his early tweed amps. Later amps use 20uF to 40uF caps. Is this a function of economics? What difference does the larger values make, lower hum, "tighter" bass, less sag? More to the point if an amp design has 40uF caps, what would the effect of putting 10 uF's or 16 uF's be.
Respectfully,
This problem calls for a bigger hammer!
Offline bigsbybender
  • Hack Of All Trades
    • Tube Amp Gallery
Re: PS Caps?
« Reply #1 on: July 19, 2011, 11:02:12 am »
Economics drove the values on the Tweed. Electrolytic caps were expensive early on. Smaller valued caps were cheaper and plentiful. As they went down in price, amp manufacturers started using larger sizes, usually capping at 40uF so as to not stress tube rectifiers.
All those things. Some designs sound more sterile with larger caps. I built a 5F1 Champ out of salvaged radio parts and used the caps that I normally stock for Blackface/Silverface designs. The filter cap that decouples the preamp ended up being a 22uF, and the amp just didn't sound right so I replaced it with an 8uF while leaving the rest of the caps at 22uF and the amp sounds great!.
More power supply noise for sure, however the amp should be a little more "loose in the low frequency" and Saggy. My personal preference is to use the higher (black and silverface) values in the power section and use the smaller (tweed) values as filters for the preamp. I think it gives the best of both worlds.
I have built a few amps with too little filtering in the power section (2x 22uF in Series for 11uF) and I never liked the result. There was too much power supply noise. Bolstering that up to 40uF while using ~10uF in the preamps always sounds great to me in Fender-style amps.
j.
Open Minded But Fixed Bias
Re: PS Caps?
« Reply #2 on: July 19, 2011, 12:28:28 pm »
I'd bet you if you went to the 1949 Sprague or Cornell Dubilier catalogs for "condensers" (They were probably called condensers more often than capacitors back then!) you would find electrolytics in 4-8-16 type values and not so much 10-20-30-40.
These values were probably derived more from the traditional values for oil-filled caps, which tended to be 4-8 ufd.
It's possible that from military parts catalogs from that era one could order 10-20 ufd caps, but that is something we know Leo Fender would not be doing! Even those grade of caps...I don't much recall 10-20 being common values from the mil-junk I have looked at and worked on from that era.
