September 08, 2026, 11:24:58 am
Hoffman Amps Forum image Author Topic: Neck Thruss Rod Nut Replacement?  (Read 5996 times)
Offline Platefire
« on: July 24, 2011, 12:35:15 am »
On the LP Studio I recently got. I changed the strings from .010-.046 to .009-.042 and I was getting a little buzzing on the first four frets. Looking down the neck it is super straight and might have a hair back bow. I decieded I would adjust the neck to back off the tention to try to get a little relief. The nut is kind of a bullet shaped with an internal hex shape for an allen wrench. I tried several allen wrenches and none seemed to fit even though I got metric and American sizes of all kinds. I think the inside hex shape is wallowed out where nothing fits.
The good thing is after I put the strings on, after a couple of days the neck seemed to re-calabrate itself and the buzzing went away and is presently playing very well. So even though the guitar is playing well with the lighter strings, I would like to know the following:
1-With the nut being wallowed out on the inside, how do you get it off for replacement.
2-Once you get it off, where do you get a replacement nut to fit the LP studio?
I would like to get this corrected for future neck adjustments. So I would appreciate help from those with experiance with this. Thanks, Platefire
On the right track now<><
Offline G._Hoffman
Re: Neck Thruss Rod Nut Replacement?
« Reply #1 on: July 24, 2011, 05:19:01 am »
For getting it off, there are a couple of ways, but Stew Mac sells THESE, which work pretty well.  Kind of expensive for one time use, though.
They also sell a variety of truss rod nuts, but I doubt any would fit your guitar, which probably requires a metric threaded nut.  If that is the case, I honestly don't know where you are going to find it.  You could try Allparts, but their website search function sucks (Their catalog is better).  If I needed one, I'd probably try to get Gibson to send me one, but it would likely be a challenge.
Gabriel
edited to fix a bad HTML tag
« Last Edit: July 24, 2011, 10:43:22 pm by G._Hoffman »
Offline Platefire
« Reply #2 on: July 24, 2011, 09:21:22 am »
Thanks Gabriel!
 The way I'm reading the info for those wrenches is instead of replacing the nut, you just use the tapered wrench instead. I would prefer to remove it and put a new nut on, but like you say a direct replacement might be hard to find. I thinking the allen that most closely fit was a 4mm. So I guess I could double check that size and just buy that single wrench. Platefire
Offline G._Hoffman
« Reply #3 on: July 24, 2011, 10:44:23 pm »
Thanks Gabriel!
Well, yes, but when you have it off you might want to check the thread on it.  If it turns out to be a 10-32, well, those are easy to find.
Gabriel
