September 08, 2026, 03:32:12 pm
Hoffman Amps Forum image Author Topic: This is an Audio PA related Question?  (Read 9661 times)
Offline Platefire
« on: August 07, 2011, 10:09:34 pm »
At our church we have wall mounted jacks on the back wall of the stage for xlr mic plug in and 1/4 phone plug going to the same channel on the main board. So for channel #6 that I use, I use the 1/4 high impedance jack for my acoutic guitar. So when I do this nothing is plugged in the xlr jack for the same channel. Well when I plug it in I would get this loud pop over the PA. I decided I would install a swich jack like we do on our guitar amps to ground the hot out when unplugged or un-ground it when I plug in. I added the switch jack but I'm still getting a pop in the PA when I plug in.
Why is this not working? is there something else I need to do? Platefire
On the right track now<><
Offline LooseChange
    • Fix Your Darn Amps
Re: This is an Audio PA related Question?
« Reply #1 on: August 08, 2011, 06:08:31 am »
My guess is the jack in the wall has a switch that's popping when you plug in. If it's a real worry, turn the levels down on the mixer first.
Call me Dan
www.fydamps.com
Offline Platefire
« Reply #2 on: August 08, 2011, 08:26:20 pm »
Can't really do that. The mixer is 50 Ft away and nobody manning it to turn it down. I need for the switch when you plug it in and the hot is ungrounded to not pop. Should be some electronic fix for that! Platefire
« Reply #3 on: August 08, 2011, 08:34:18 pm »
Why not just leave it plugged in all the time?
Offline Platefire
« Reply #4 on: August 10, 2011, 12:08:38 am »
On my acoustic, the preamp switches on when you plug it in(no switch knob). That means my battery would be running during the whole church service (2.5 hours) even when I wasn't using it. You have to access the battery through the sound hole--making it a hassle to change--so I plug in my cord just before I do my songs and unplug as soon as I get through to save batteries.
The idea is save people from enduring a loud pop through the PA mains when I plug in and un-plug--by leaving it plugged in I would have to plug it in before sunday school and unplug it at end of preaching service, a period of about 2.5 hours. Platefire
« Reply #5 on: August 10, 2011, 12:08:26 pm »
Try an A/B switch between your guitar and the wall jack. Switch the A/B off before inserting/removing the plug from your guitar.
Offline Platefire
« Reply #6 on: August 10, 2011, 12:25:33 pm »
Yow, I have an A/B/Y box. Thant is worth a try. Thanks, Platefire
