September 08, 2026, 11:24:12 am
Hoffman Amps Forum image Author Topic: Tele bridge route question  (Read 6378 times)
Offline worth
« on: August 12, 2011, 09:49:36 am »
 A lot of modern Fenders are routed to allow the use of different pickups other than a single coil. Without my removing the bridge-plate assembley on my '98 Americen Standard Tele.... does anybody know if the body under the bridge has been routed for the alternate use of humbuckers. I realise a different Tele bridge assembly would have to be installed for a humbucker. ( I don't want to use a single coil - size humbucker. )
Offline stingray_65
Re: Tele bridge route question
« Reply #1 on: August 12, 2011, 11:43:54 am »
I can not say specifically,for your 98, but I've not seen a Genuine Fender Telecaster routed for anything but single coils.
The exception would be the MIM reissue Custom, Deluxe, and Thinlines that were routed specifically for the reissue Lover WRHB's.
I've recently recommended this forum:
http://www.tdpri.com/
Friendly like this forum, just everything Telecaster, Lot of VERY informed people on there
Ray
Offline worth
« Reply #2 on: August 12, 2011, 12:14:46 pm »
No.. my '98 American Standard is routed for ANY configuration under the pickguard. Right now I have a humbucker - shaped Gibson P-90. So , I wondered if the same was true for the bridge route.
Offline stingray_65
« Reply #3 on: August 12, 2011, 12:17:10 pm »
Good info to know! thanks!
I'll bet the fellas at TDPRI will give you accurate info.
Ray
