September 16, 2026, 08:56:30 pm
Hoffman Amps Forum image Author Topic: Parallel Front End  (Read 6216 times)
Parallel Front End
« on: August 13, 2011, 03:28:49 am »
Hi guys, Got some sound out of my new build  :m15 but it comes with the usual unwanted noises. First i will address the front end,as per the preamp schem i have a switch that gives a normal plexi input or a parallel input.The difference between the two is that when parallel is selected it does give a very nice fat sound as expected and i think i will remove the switch a just have a parallel input. At one point of the test i did get some radio noise.Also when in parallel the second 1M resistor is also in the circuit, so would i need to increase the 1M to a 2.2m and do i need the 68k resistor (i'm not sure what you call that resistor). I could not find much on this type of parallel input, more info please. Thanks
Re: Parallel Front End
« Reply #1 on: August 13, 2011, 06:15:25 am »
Yes, with the multiple gain stages I definitely think you should add the input resistor. Use 68k if parallel inputs or 33k if single inputs.
With a simple SPDT switch, you can get THREE different tones out of your paralleled 12A_7. A very cheap and useful mod to add in my opinion. I've done this on a bunch of amps.
Offline jeff
  • Need input
« Reply #2 on: August 13, 2011, 03:42:01 pm »
The two 1M are in parallel. If you wanted to use only one resistor you'd need a 500K not a 2M.
With the 68K, I often wonerded. Two 68K in parallel is 34K resistance, but the point of the 68K is to attunuate the radio frequencies because of the miller effect does one 34K have the same effect as two 68K?
Just as an example to illustrate the point and ask the question another way:
Say you had one hundred 3M4s in parallel. The resistance would be 34K but would the miller effect be the same thing as using one 34K?The resistance goes down because there is 100 paths but each path is 3M4. Using two 68K also gives 34K but each path is 68K.
 I've been using one single 68K. The resistance is bigger but won't the input voltage be the same because the grids impedance? Some reason I'd think one 68K would give you more attenuation without a reduction in input signal vs one 34K.
Been meaning to ask this. In the end it probally doesn't matter, just another "how does it work" question.
« Last Edit: August 13, 2011, 03:53:15 pm by jeff »
« Reply #3 on: August 13, 2011, 03:52:18 pm »
That's just a secondary benefit of those resistors. The real purpose was isolation between the input jacks. Back in the day when those resistors first appeared, it was very common to have 2 or more instruments plugged into one amp. Those resistors isolated the jacks from each other and prevented the volume control of one guitar from controlling the other guitar.
Fat Clean inputs with switching jacks
« Reply #4 on: August 13, 2011, 05:14:33 pm »
FWIW I'm intrigued by the simple versatility of this circuit from Merlin
« Reply #5 on: August 14, 2011, 01:01:04 am »
Thanks for the info, and like a good little boy i listen to both of you and added both ideas and it was a good result. It has add depth to the sound but i am unable to get a real feel for it due to........... WAIT FOR IT........ THE BUZZ IS BACK  :sad2: I don't know why i do these things but i like the challenge  :BangHead:
« Reply #6 on: August 14, 2011, 04:48:31 am »
grounding? How is your grounding done?
« Reply #7 on: August 14, 2011, 06:07:29 am »
Timbo,
Buzz is probably a grounding issue or a problem with an input jack.  I strongly recommend using a 33k input resistor and using a 1M resistor to ground.
Is there some reason to use two input jacks?
with respect, Tubenit
« Reply #8 on: August 17, 2011, 12:02:32 am »
Tubenit i'm not understanding your question. Thanks
« Reply #9 on: August 17, 2011, 02:21:43 pm »
Timbo,
Wasn't it the Silver Jubilee amp prior that had the buzzing issue? And now you have a different amp and another buzzing issue?
I think tubenit was saying why do you feel the need to have two inputs instead of only one? Personally I don't think there's anything wrong w/ having Hi and Lo inputs if that's what you have? Sorry, not on home computer so can't look at your schematics right now.
« Reply #10 on: August 18, 2011, 03:39:14 am »
Hey jojokeo,I was only wanting one input as i think there is other ways to achieve the highs and lows.And yes the jubilee did have a buzz problem but it was the relay circuit that was causing it a 50ohm resistor to ground was added to the - side and thanks to Sluckey, gone.
I even have thoughts that the DC circuit could be doing the same thing  :dontknow: Thanks
