September 19, 2026, 02:17:07 am
Hoffman Amps Forum image Author Topic: Wah-wah that hums - Ground loop?  (Read 12412 times)
Offline dude
« on: August 18, 2011, 11:53:49 am »
Nothing but the Wah wah pedal and it hums, take it out go straight to amp, quite.
I read about a ground loop but don't know the fix with a pedal.
If I turn the pedal off, no hum.
Any suggestions? I did search and found the ground loop could be causing the problem.
But the fix?
thanks,
al
Re: Wah-wah that hums - Ground loop?
« Reply #1 on: August 18, 2011, 12:37:51 pm »
Does it hum regardless of which amp it's connected to?
Offline dude
« Reply #2 on: August 18, 2011, 11:50:11 pm »
Yes any amp, alone or with other pedals in a chain.
It's definitively the wah-wah pedal if I leave the wah off no hum.
I play an 18 watt Trinity SIII TMB, which plays great no hum alone or with these three pedals, strat into a Boss CS-2 compression, then Ibanez TS10 (modded to 808 specs) and sometimes an Ibanez GE10 EQ. I just started to try the wah-wah and put it first in the chain.
Just the strat and wah and it hums too, no other hum with any of the other pedals just when I add the wah in the front.
al
Offline VMS
« Reply #3 on: August 20, 2011, 09:25:41 am »
What wah-wah pedal are you using?
Is it powered with battery or a power supply?
Offline dude
« Reply #4 on: August 20, 2011, 09:41:20 am »
Crybaby, from the late eighties or early nineties.
Model GCB-95,  made in USA
external power supply at 9.45v dc
al
Offline VMS
« Reply #5 on: August 20, 2011, 10:12:37 am »
Try and see what happens with battery.
Offline dude
« Reply #6 on: August 25, 2011, 04:26:48 pm »
Sorry for the long delay getting back, I didn't have a good 9 volt and kept forgetting every time I went out.
Anyway, Bingo works great no hum at all.
So I guess I'm limited to a 9 volt for the wah?
thanks,
al
« Reply #7 on: August 28, 2011, 08:52:43 pm »
Maybe get a better power supply.
My old Thomas Organ Cry Baby works fine with my power supply and it was never meant to be used with anything except a battery.
