September 15, 2026, 05:59:47 pm
Hoffman Amps Forum image Author Topic: parallel 6V6 5F1 output primary ?  (Read 6298 times)
Offline worth
« on: August 19, 2011, 12:28:03 pm »
In about an hour I'll power up this build , but I need a recommendation for the OT primary impedance. The OT is a Doberman/ Heyboer with a choice of 2.5K , 4K , or 6K primary. I'll be using the 8 ohm secondary.
stratele52
  • Guest
Re: parallel 6V6 5F1 output primary ?
« Reply #1 on: August 19, 2011, 12:37:08 pm »
You talk about 2 parallele  6V6 not push-pull.  A single ended transformer with a primary of 4 k to 5 K work fine.
« Reply #2 on: August 19, 2011, 01:21:30 pm »
2K5
adjust Rk to set Pdiss ~20 to 22 W for both 6V6.
-DL
« Reply #3 on: August 19, 2011, 07:01:48 pm »
Either 2k5 or 4k for 2 x parallel 6V6s
« Reply #4 on: August 20, 2011, 12:45:24 am »
Why? Power-up, try them all. Won't hurt the amp.
Offline Geezer
« Reply #5 on: August 20, 2011, 04:56:30 am »
Right on!    You may be surprized @ what your ears "recommend"  :icon_biggrin:
G
« Reply #6 on: August 20, 2011, 11:52:51 pm »
Also: there is not sufficient data presented to ball-park a "right" answer. Wanna know plate voltage and current. Since this is not a stock 5F1, and may use un-stock PT, even comparison to "similar" amps may be folly.
As long as you have a speaker on a near-right impedance tap, you can use ANY primary impedance on cathode-bias amps. Get different power and flavor, but shouldn't hurt anything.
