September 15, 2026, 05:00:41 pm
Hoffman Amps Forum image Author Topic: Power Amp in on Marshall 2204?  (Read 5461 times)
Offline JustMike
« on: August 24, 2011, 08:05:23 am »
 I tried it just before the MV and it works, but not enough gain. So if I back it up to pin 2 on V2, am I not in the tone stack now? I want to be able to plug in an external preamp to the Marshall power stage.
 Thanks!
I'm learning...
Offline stingray_65
Re: Power Amp in on Marshall 2204?
« Reply #1 on: August 24, 2011, 09:35:26 am »
Mike,
I can't give much insight to your problem, but I do know that the guys here will be able to help you with a bit more info.
I do know that impedance matching is important to this sort of thing, so maybe if you tel us what kind of pre amp you;re using would be helpfull.
Ray
Offline JustMike
« Reply #2 on: August 24, 2011, 10:12:08 am »
 I've tried it with a Boss GT-6 and a B.K. Butler Blue Tube. The sound is clean, but not 50w Marshall loud.
I'm learning...
« Reply #3 on: August 24, 2011, 10:46:00 am »
That's the best place to connect an external preamp input. You'll need to provide the desired gain with your external preamp.
yes
Offline Tone Junkie
« Reply #4 on: August 24, 2011, 11:50:06 am »
I would say look in the schematic archive and find how marshall did it with there stand alone power amps and copy that.
Bill
Offline Boots Deville
« Reply #5 on: August 24, 2011, 12:16:31 pm »
I just looked up the GT-6 to see what kind of outputs it has.  The nominal output level of the "output" is listed as 0dB and for the "send" it's -10dB.  If you're using the "Send" for some reason, try the "output".
Then I noticed the info I've attached - did you try those different output modes?
Sometimes stand-alone power amps have an input stage before the PI.  Refer to the AX84 link for an example.  That may be what you need here.
http://www.ax84.com/static/corepoweramps/Standalone_PP/AX84_Standalone_PP_Poweramp_Schematic.pdf
